Possible issues and solutions while installing on Fedora 1
Posted: Wed Aug 25, 2004 8:03 am
Hi, this is my first post.
As a small contribution to this exciting project, this is a description of how I got ZM working on my Fedora Core 1 system.
First of all, I installed MySql packages :
- mysql
- php-mysql
- mysql-server
- mysql-devel
Apache was already installed.
Dependencies :
- Perl-DBI
- Perl-DBD-MySQL
I also installed these packages found on dag.wieers.com :
- Perl-Data-Showtable
- Perl-Term-Clui
- Perl-Term-Readline-Gnu
I'm not sure about these packages being needed or no though.
- libjpeg-devel is needed too
yum installed these packages :
- netpbm
- netpbm-progs
As described in the docs, I imported the database schema in MySQL and renamed the DB "zm".
Next..
I had several issue while running ./configure...
It kept saying my cpp (/lib/cpp) had sanity check issues.
Packages needed in this case :
- gcc-c++
- libstdc++-devel
- zlib-devel
Next issue, libmysqlclient.a missing.. I slocated the file in /usr/lib/mysql..
Just symlink the file in /usr/lib
./configure then went thru
This is the command I issued for my system :
./configure --with-mysql=/var/lib/mysql --with-cgidir=/var/www/cgi-bin --with-webdir=/var/www/html/apps/zm
My www root directory is /var/www/html/apps/
You'll need this in your httpd.conf file :
Then restart Apache.
Once ./configure correctly went thru, type :
perl zmconfig.pl
You'll be asked many questions about the program, you need to be careful about the database name and host, the other questions as far as I remember are not critical since you can change these settings later on.
then issue "perl zmconfig.pl -noi" (don't ask me why, I have no clue.. found that on the forum)
make
make install
zpkg.pl start and http://server/apps/zm
You're in ZM console !
You need to create your monitor, considering your webcam is running properly on your system.
The most important tab when creating a monitor is the second one.
This is what I entered
Device Number (/dev/video?) : 0
Device Channel : 0
Device Format (0=PAL,1=NTSC etc) 0
Capture Palette YUV420P (works fine for me, depends on your cam)
Capture Width (pixels) 320
Capture Height (pixels) 240
Orientation Normal
Here we assume the cam is running on /dev/video0..
You should see the picture now.. if you don't double check cgi-bin is correctly set in apache config file.
Now you can have fun testing the different settings.. record, modect,..
If you don't have your webcam installed on your machine..
This is my experience, I have a Creative Webcam 3 or Plus, I never really knew.. it uses ov511..
I had USB deactivated on my system.. and in the BIOS.. (I wasted one hour wondering why USB wouldn't work )
When it restarted after enabling USB under BIOS, kudzu detected the new hardware and installed USB..
I would install pciutils if I were you, just to know which usb-uhci or usb-ohci you will need to use.. Once it's installed :
lspci -vv and check in the output
I needed uhci..
modprobe usbcore
modprobe usb-uhci <OR> modprobe usb-ohci
modprobe videodev
modprobe ov511
Then the camera was working !
Check alpha.dyndns.org for more info
Now, if i issue "lsmod" this is the output
ov511 81440 1
videodev 8288 1 [ov511]
keybdev 2656 0 (unused)
mousedev 5268 0 (unused)
hid 23908 0 (unused)
input 5888 0 [keybdev mousedev hid]
usb-uhci 26124 0 (unused)
usbcore 78752 1 [ov511 hid usb-uhci]
In the configuration of ZM I wanted to set the authentification on.
I wasn't able to log in entering the passwork I specified.. I still need to figure this out. To get back to the old setting I needed to change the value of "ZM_OPT_USE_AUTH" in MySQL to 0.
When starting MySQL it says it didn't start and times out.. SQL is correctly running though.. it's an issue about InnoDB that I still need to figure out.
I couldn't edit zones, you just need to grant access to the unprivileged user to your SQL DB..
Sometimes I can't access my server after a while I'm connected to ZM at home, it's my WinXP installation that messes around..
VoilĂ ! Hope this helps you out !
Note : I didn't figure out everything yet, there may be errors in my installation process.. correct me if I'm wrong of if I missed something or anything !
If you need help, you can always ask and I will try to help you !
Note 2 : I had my camera running on RH7.3 and FC1 always using ov511 drivers.. the camera tends to get redish when on low light.. the quality is quite poor... if someone had the experience and has a clue on how to improve that.. any info is welcome
Seb
- mysql
- php-mysql
- mysql-server
- mysql-devel
Dependencies :
- Perl-DBI
- Perl-DBD-MySQL
- Perl-Term-Clui
- netpbm
- netpbm-progs
Next..
- gcc-c++
- libstdc++-devel
- zlib-devel
perl zmconfig.pl
make
make install
Device Channel : 0
Orientation Normal
I needed uhci..
modprobe usbcore
modprobe videodev
modprobe ov511
ov511 81440 1
Seb
