Page 1 of 3
linux crashing - $500 bounty!
Posted: Tue Aug 31, 2004 8:38 am
by seanadams
This is killer software and I'm more than willing to make a significant donation to the author if someone can help me get it up and running on my machine. The problem I'm having is that my system just crashes hard and reboots (no panic/debug info on console) a few minutes after I start zoneminder. My video card is the spectra8 and I did the install myself starting from Mandrake 10.0 (did not use LiveCD). The system is perfectly stable when zm is not running.
I've read through many of the threads here, and have tried all of the following:
- Tried two different motherboards. First was an Asus P4. On this system the crashes would happen after approx 15-30 minutes. I figured it was probably bad hardware and I didn't worry about it because I had planned to use a faster SMP machine. So I got this dual opeteron board (Master2 K8T) and I am still seeing the problem. Except on this motherboard it crashes faster - about 30 sec to 1 minute after starting zoneminder.
- I've run memtest86 for over 24 hours with no errors. The machine has 1GB registered memory.
- I've tried upgrading to linux v 2.6.8 and also downgrading to 2.4.27. The system crashes in the same way with either of these kernels, as well as the stock 2.6.3-7mdk kernel.
- Tried adding append="noapic pci=noacpi" to lilo.conf. Made no difference in the crashing except that with these options turned on it printed a message about "disabling irq 12" when I started zoneminder.
- I have tried disabling the bios setting to "assign IRQ to VGA card". Did not make any difference.
- I've googled, I've read the forums, I've whacked my head against the keyboard but I'm getting nowhere here. Please help!!!
I'm a software/hardware guy, and more than willing to do a reasonable amount of troubleshooting, but will need some guidance as I don't know diddly about how to debug kernel crashes like this.
[sadams@sean sadams]$ dmesg
0 00000010
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
CPU0: AMD Opteron(tm) Processor 242 stepping 0a
per-CPU timeslice cutoff: 2926.77 usecs.
task migration cache decay timeout: 3 msecs.
enabled ExtINT on CPU#0
ESR value before enabling vector: 00000000
ESR value after enabling vector: 00000000
Booting processor 1/1 eip 2000
Initializing CPU#1
masked ExtINT on CPU#1
Calibrating delay loop... 3203.07 BogoMIPS
CPU: After generic identify, caps: 078bfbff e1d3fbff 00000000 00000000
CPU: After vendor identify, caps:  078bfbff e1d3fbff 00000000 00000000
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 1024K (64 bytes/line)
CPU: After all inits, caps:        078bfbff e1d3fbff 00000000 00000010
Intel machine check reporting enabled on CPU#1.
CPU1: AMD Opteron(tm) Processor 242 stepping 0a
Total of 2 processors activated (6348.80 BogoMIPS).
Using local APIC timer interrupts.
calibrating APIC timer ...
..... CPU clock speed is 1603.0394 MHz.
..... host bus clock speed is 200.0424 MHz.
checking TSC synchronization across 2 CPUs: passed.
Brought up 2 CPUs
CPU0:  online
 domain 0: span 03
  groups: 01 02
CPU1:  online
 domain 0: span 03
  groups: 02 01
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Freeing initrd memory: 108k freed
NET: Registered protocol family 16
EISA bus registered
PCI: PCI BIOS revision 2.10 entry at 0xfb070, last bus=2
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
Linux Plug and Play Support v0.97 (c) Adam Belay
PnPBIOS: Scanning system for PnP BIOS support...
PnPBIOS: Found PnP BIOS installation structure at 0xc00fbb40
PnPBIOS: PnP BIOS version 1.0, entry 0xf0000:0xbb70, dseg 0xf0000
PnPBIOS: 14 nodes reported by PnP BIOS; 14 recorded by driver
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
PCI: Using IRQ router VIA [1106/3227] at 0000:00:11.0
vesafb: probe of vesafb0 failed with error -6
Starting balanced_irq
highmem bounce pool size: 64 pages
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
Initializing Cryptographic API
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 8 ports, IRQ sharing enabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 32000K size 1024 blocksize
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:0f.0
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci0000:00:0f.0
    ide0: BM-DMA at 0xd000-0xd007, BIOS settings: hda:DMA, hdb:pio
    ide1: BM-DMA at 0xd008-0xd00f, BIOS settings: hdc:DMA, hdd:pio
hda: Maxtor 2F020J0, ATA DISK drive
Using anticipatory io scheduler
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hdc: SONY CD-ROM CDU5221, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
hda: max request size: 128KiB
hda: 40718160 sectors (20847 MB) w/2048KiB Cache, CHS=40395/16/63, UDMA(133)
 /dev/ide/host0/bus0/target0/lun0: p1 p2 < p5 p6 >
mice: PS/2 mouse device common for all mice
spurious 8259A interrupt: IRQ7.
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
input: AT Translated Set 2 keyboard on isa0060/serio0
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
EISA: Probing bus 0 at eisa0
NET: Registered protocol family 2
IP: routing cache hash table of 8192 buckets, 64Kbytes
TCP: Hash tables configured (established 262144 bind 65536)
BIOS EDD facility v0.16 2004-Jun-25, 1 devices found
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
RAMDISK: Compressed image found at block 0
VFS: Mounted root (ext2 filesystem).
Mounted devfs on /dev
jbd: disagrees about version of symbol __getblk
jbd: Unknown symbol __getblk
jbd: disagrees about version of symbol mark_buffer_dirty
jbd: Unknown symbol mark_buffer_dirty
jbd: disagrees about version of symbol __find_get_block
jbd: Unknown symbol __find_get_block
jbd: disagrees about version of symbol __bforget
jbd: Unknown symbol __bforget
jbd: disagrees about version of symbol submit_bh
jbd: Unknown symbol submit_bh
jbd: disagrees about version of symbol alloc_buffer_head
jbd: Unknown symbol alloc_buffer_head
jbd: disagrees about version of symbol wake_up_process
jbd: Unknown symbol wake_up_process
jbd: Unknown symbol refrigerator
jbd: disagrees about version of symbol init_buffer
jbd: Unknown symbol init_buffer
jbd: disagrees about version of symbol try_to_free_buffers
jbd: Unknown symbol try_to_free_buffers
jbd: disagrees about version of symbol sync_blockdev
jbd: Unknown symbol sync_blockdev
jbd: disagrees about version of symbol bdevname
jbd: Unknown symbol bdevname
jbd: disagrees about version of symbol free_buffer_head
jbd: Unknown symbol free_buffer_head
jbd: disagrees about version of symbol __brelse
jbd: Unknown symbol __brelse
jbd: disagrees about version of symbol unlock_page
jbd: Unknown symbol unlock_page
jbd: disagrees about version of symbol sync_dirty_buffer
jbd: Unknown symbol sync_dirty_buffer
jbd: disagrees about version of symbol __wait_on_buffer
jbd: Unknown symbol __wait_on_buffer
jbd: disagrees about version of symbol wake_up_buffer
jbd: Unknown symbol wake_up_buffer
jbd: disagrees about version of symbol set_bh_page
jbd: Unknown symbol set_bh_page
jbd: disagrees about version of symbol unlock_buffer
jbd: Unknown symbol unlock_buffer
jbd: disagrees about version of symbol __lock_buffer
jbd: Unknown symbol __lock_buffer
jbd: disagrees about version of symbol ll_rw_block
jbd: Unknown symbol ll_rw_block
jbd: disagrees about version of symbol bh_waitq_head
jbd: Unknown symbol bh_waitq_head
ext3: disagrees about version of symbol generic_block_bmap
ext3: Unknown symbol generic_block_bmap
ext3: disagrees about version of symbol bd_claim
ext3: Unknown symbol bd_claim
ext3: disagrees about version of symbol set_blocksize
ext3: Unknown symbol set_blocksize
ext3: disagrees about version of symbol __getblk
ext3: Unknown symbol __getblk
ext3: disagrees about version of symbol generic_file_readv
ext3: Unknown symbol generic_file_readv
ext3: disagrees about version of symbol mark_buffer_dirty
ext3: Unknown symbol mark_buffer_dirty
ext3: disagrees about version of symbol __find_get_block
ext3: Unknown symbol __find_get_block
ext3: disagrees about version of symbol block_sync_page
ext3: Unknown symbol block_sync_page
ext3: disagrees about version of symbol __blockdev_direct_IO
ext3: Unknown symbol __blockdev_direct_IO
ext3: disagrees about version of symbol sb_set_blocksize
ext3: Unknown symbol sb_set_blocksize
ext3: disagrees about version of symbol get_sb_bdev
ext3: Unknown symbol get_sb_bdev
ext3: disagrees about version of symbol end_buffer_read_sync
ext3: Unknown symbol end_buffer_read_sync
ext3: disagrees about version of symbol submit_bh
ext3: Unknown symbol submit_bh
ext3: disagrees about version of symbol kill_block_super
ext3: Unknown symbol kill_block_super
ext3: disagrees about version of symbol generic_commit_write
ext3: Unknown symbol generic_commit_write
ext3: disagrees about version of symbol create_empty_buffers
ext3: Unknown symbol create_empty_buffers
ext3: disagrees about version of symbol sync_blockdev
ext3: Unknown symbol sync_blockdev
ext3: disagrees about version of symbol block_write_full_page
ext3: Unknown symbol block_write_full_page
ext3: disagrees about version of symbol bdevname
ext3: Unknown symbol bdevname
ext3: disagrees about version of symbol generic_file_mmap
ext3: Unknown symbol generic_file_mmap
ext3: disagrees about version of symbol generic_file_sendfile
ext3: Unknown symbol generic_file_sendfile
ext3: disagrees about version of symbol blkdev_put
ext3: Unknown symbol blkdev_put
ext3: disagrees about version of symbol open_by_devnum
ext3: Unknown symbol open_by_devnum
ext3: disagrees about version of symbol __brelse
ext3: Unknown symbol __brelse
ext3: disagrees about version of symbol unlock_page
ext3: Unknown symbol unlock_page
ext3: disagrees about version of symbol sync_dirty_buffer
ext3: Unknown symbol sync_dirty_buffer
ext3: disagrees about version of symbol __wait_on_buffer
ext3: Unknown symbol __wait_on_buffer
ext3: disagrees about version of symbol find_or_create_page
ext3: Unknown symbol find_or_create_page
ext3: disagrees about version of symbol sync_inode
ext3: Unknown symbol sync_inode
ext3: disagrees about version of symbol mpage_readpage
ext3: Unknown symbol mpage_readpage
ext3: disagrees about version of symbol mpage_readpages
ext3: Unknown symbol mpage_readpages
ext3: disagrees about version of symbol invalidate_bdev
ext3: Unknown symbol invalidate_bdev
ext3: disagrees about version of symbol block_prepare_write
ext3: Unknown symbol block_prepare_write
ext3: disagrees about version of symbol generic_file_aio_write
ext3: Unknown symbol generic_file_aio_write
ext3: disagrees about version of symbol redirty_page_for_writepage
ext3: Unknown symbol redirty_page_for_writepage
ext3: disagrees about version of symbol unlock_buffer
ext3: Unknown symbol unlock_buffer
ext3: disagrees about version of symbol generic_file_writev
ext3: Unknown symbol generic_file_writev
ext3: disagrees about version of symbol generic_file_aio_read
ext3: Unknown symbol generic_file_aio_read
ext3: disagrees about version of symbol __lock_buffer
ext3: Unknown symbol __lock_buffer
ext3: disagrees about version of symbol ll_rw_block
ext3: Unknown symbol ll_rw_block
ext3: disagrees about version of symbol bdev_read_only
ext3: Unknown symbol bdev_read_only
ext3: disagrees about version of symbol bd_release
ext3: Unknown symbol bd_release
ext3: disagrees about version of symbol __set_page_dirty_nobuffers
ext3: Unknown symbol __set_page_dirty_nobuffers
ext3: disagrees about version of symbol __mark_inode_dirty
ext3: Unknown symbol __mark_inode_dirty
ext3: disagrees about version of symbol __bread
ext3: Unknown symbol __bread
ext3: disagrees about version of symbol sb_min_blocksize
ext3: Unknown symbol sb_min_blocksize
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
kjournald starting.  Commit interval 5 seconds
EXT3-fs: hda1: orphan cleanup on readonly fs
ext3_orphan_cleanup: deleting unreferenced inode 567648
ext3_orphan_cleanup: deleting unreferenced inode 567647
EXT3-fs: hda1: 2 orphan inodes deleted
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
Freeing unused kernel memory: 284k freed
Real Time Clock Driver v1.12
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v2.2
PCI: Found IRQ 11 for device 0000:00:10.0
PCI: Sharing IRQ 11 with 0000:00:0b.0
PCI: Sharing IRQ 11 with 0000:00:10.1
uhci_hcd 0000:00:10.0: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller
uhci_hcd 0000:00:10.0: irq 11, io base 0000d400
uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
PCI: Found IRQ 11 for device 0000:00:10.1
PCI: Sharing IRQ 11 with 0000:00:10.0
uhci_hcd 0000:00:10.1: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (#2)
uhci_hcd 0000:00:10.1: irq 11, io base 0000d800
uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
PCI: Found IRQ 10 for device 0000:00:10.2
uhci_hcd 0000:00:10.2: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (#3)
uhci_hcd 0000:00:10.2: irq 10, io base 0000dc00
uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
PCI: Found IRQ 5 for device 0000:00:10.4
PCI: Sharing IRQ 5 with 0000:00:11.5
ehci_hcd 0000:00:10.4: VIA Technologies, Inc. USB 2.0
ehci_hcd 0000:00:10.4: irq 5, pci mem f8804000
ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 4
ehci_hcd 0000:00:10.4: USB 2.0 enabled, EHCI 1.00, driver 2004-May-10
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 6 ports detected
usb 3-1: new low speed USB device using address 2
usbcore: registered new driver hiddev
input: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:10.2 -1
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.0:USB HID core driver
usbcore: registered new driver usbmouse
drivers/usb/input/usbmouse.c: v1.6:USB HID Boot Protocol mouse driver
ts: Compaq touchscreen protocol output
EXT3 FS on hda1, internal journal
Adding 506008k swap on /dev/hda5.  Priority:-1 extents:1
Linux agpgart interface v0.100 (c) Dave Jones
agpgart: Detected AGP bridge 0
agpgart: Maximum main memory to use for agp memory: 940M
agpgart: AGP aperture is 128M @ 0xe0000000
EXT3 FS on hda6, internal journal
Broadcom Gigabit Ethernet Driver bcm5700 with Broadcom NIC Extension (NICE) ver.  7.3.5 (06/23/04)
PCI: Found IRQ 11 for device 0000:00:0b.0
eth0: Broadcom BCM5705 1000Base-T found at mem ea100000, IRQ 11, node addr 00110 93fd8ec
eth0: Broadcom BCM5705 Integrated Copper transceiver found
eth0: Scatter-gather ON, 64-bit DMA ON, Tx Checksum ON, Rx Checksum ON, 802.1Q V LAN ON, TSO ON
ip_tables: (C) 2000-2002 Netfilter core team
ip_conntrack version 2.1 (8183 buckets, 65464 max) - 300 bytes per conntrack
inserting floppy driver for 2.6.8
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
hdc: ATAPI 40X CD-ROM drive, 128kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
ide-floppy driver 0.99.newide
NET: Registered protocol family 17
via82xx: Assuming DXS channels with 48k fixed sample rate.
         Please try dxs_support=1 or dxs_support=4 option
         and report if it works on your machine.
PCI: Found IRQ 5 for device 0000:00:11.5
PCI: Sharing IRQ 5 with 0000:00:10.4
PCI: Setting latency timer of device 0000:00:11.5 to 64
bcm5700: eth0 NIC Link is UP, 1000 Mbps full duplex, receive & transmit flow con trol ON
NET: Registered protocol family 10
Disabled Privacy Extensions on device c0393bc0(lo)
IPv6 over IPv4 tunneling driver
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
lp0: using parport0 (interrupt-driven).
lp0: console ready
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
eth0: no IPv6 routers present
atkbd.c: Spurious ACK on isa0060/serio0. Some program, like XFree86, might be tr ying access hardware directly.
SCSI subsystem initialized
st: Version 20040403, fixed bufsize 32768, s/g segs 256
cdrom: This disc doesn't have any tracks I recognize!
[sadams@sean sadams]$ cat /proc/pci
PCI devices found:
  Bus  0, device   0, function  0:
    Host bridge: VIA Technologies, Inc. VT8385 [K8T800 AGP] Host Bridge (rev 1).
      Master Capable.  Latency=8.
      Prefetchable 32 bit memory at 0xe0000000 [0xe7ffffff].
  Bus  0, device   1, function  0:
    PCI bridge: VIA Technologies, Inc. VT8237 PCI bridge [K8T800 South] (rev 0).
      Master Capable.  No bursts.  Min Gnt=8.
  Bus  0, device   8, function  0:
    PCI bridge: Hint Corp HB6 Universal PCI-PCI bridge (non-transparent mode) (rev 17).
      Master Capable.  Latency=32.  Min Gnt=6.
  Bus  0, device  11, function  0:
    Ethernet controller: Broadcom Corporation NetXtreme BCM5705 Gigabit Ethernet (rev 3).
      IRQ 11.
      Master Capable.  Latency=32.  Min Gnt=64.
      Non-prefetchable 64 bit memory at 0xea100000 [0xea10ffff].
  Bus  0, device  15, function  0:
    IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 6).      Master Capable.  Latency=32.
      I/O at 0xd000 [0xd00f].
  Bus  0, device  16, function  0:
    USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 129).
      IRQ 11.
      I/O at 0xd400 [0xd41f].
  Bus  0, device  16, function  1:
    USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (#2) (rev 129).
      IRQ 11.
      I/O at 0xd800 [0xd81f].
  Bus  0, device  16, function  2:
    USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (#3) (rev 129).
      IRQ 10.
      I/O at 0xdc00 [0xdc1f].
  Bus  0, device  16, function  4:
    USB Controller: VIA Technologies, Inc. USB 2.0 (rev 134).
      IRQ 5.
      Non-prefetchable 32 bit memory at 0xea110000 [0xea1100ff].
  Bus  0, device  17, function  0:
    ISA bridge: VIA Technologies, Inc. VT8237 ISA bridge [K8T800 South] (rev 0).
  Bus  0, device  17, function  5:
    Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 96).      IRQ 5.
      I/O at 0xe400 [0xe4ff].
  Bus  0, device  24, function  0:
    Host bridge: Advanced Micro Devices [AMD] K8 NorthBridge (rev 0).
  Bus  0, device  25, function  0:
    Host bridge: Advanced Micro Devices [AMD] K8 NorthBridge (#2) (rev 0).
  Bus  0, device  24, function  1:
  Bus  0, device  25, function  1:
  Bus  0, device  24, function  2:
  Bus  0, device  25, function  2:
  Bus  0, device  24, function  3:
  Bus  0, device  25, function  3:
  Bus  1, device   0, function  0:
    VGA compatible controller: Silicon Integrated Systems [SiS] 315PRO PCI/AGP VGA Display Adapter (rev 0).
      Master Capable.  Latency=39.  Min Gnt=3.Max Lat=16.
      Prefetchable 32 bit memory at 0xd0000000 [0xdfffffff].
      Non-prefetchable 32 bit memory at 0xe9000000 [0xe903ffff].
      I/O at 0xc000 [0xc07f].
  Bus  2, device   8, function  0:
    Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 17).
      IRQ 12.
      Master Capable.  Latency=32.  Min Gnt=16.Max Lat=40.
      Prefetchable 32 bit memory at 0xea000000 [0xea000fff].
  Bus  2, device   9, function  0:
    Multimedia video controller: Brooktree Corporation Bt878 Video Capture (#2) (rev 17).
      IRQ 11.
      Prefetchable 32 bit memory at 0xea002000 [0xea002fff].
  Bus  2, device  10, function  0:
    Multimedia video controller: Brooktree Corporation Bt878 Video Capture (#3) (rev 17).
      IRQ 10.
      Prefetchable 32 bit memory at 0xea004000 [0xea004fff].
  Bus  2, device  11, function  0:
    Multimedia video controller: Brooktree Corporation Bt878 Video Capture (#4) (rev 17).
      IRQ 5.
      Prefetchable 32 bit memory at 0xea006000 [0xea006fff].
  Bus  2, device   8, function  1:
    Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 17).
      IRQ 12.
      Master Capable.  Latency=32.  Min Gnt=4.Max Lat=255.
      Prefetchable 32 bit memory at 0xea001000 [0xea001fff].
  Bus  2, device   9, function  1:
    Multimedia controller: Brooktree Corporation Bt878 Audio Capture (#2) (rev 17).
      IRQ 11.
      Prefetchable 32 bit memory at 0xea003000 [0xea003fff].
  Bus  2, device  10, function  1:
    Multimedia controller: Brooktree Corporation Bt878 Audio Capture (#3) (rev 17).
      IRQ 10.
      Prefetchable 32 bit memory at 0xea005000 [0xea005fff].
  Bus  2, device  11, function  1:
    Multimedia controller: Brooktree Corporation Bt878 Audio Capture (#4) (rev 17).
      IRQ 5.
      Prefetchable 32 bit memory at 0xea007000 [0xea007fff].
Posted: Tue Aug 31, 2004 9:43 am
by seanadams
Addenda:
1) After deleting my second camera, the system no longer crashes.
2) However, I am also not getting any video now. Perhaps I b0rked something while I was flipping kernel revs back and forth?
xawtv just shows a black screen. when starting xawtv I get this in /var/log/messages:
bttv0: reset, initialize
bttv0: timeout: drop=0 irq=4/96585, risc=3121d03c, bits: FMTCHG VSYNC HSYNC OFLOW RISCI
And when I run zm I get this:
ERR [Shared memory not initialized by capture daemon]
I seem to remember fixing this before when I was setting up zm but now I forget what I did. Sigh...
Posted: Tue Aug 31, 2004 10:05 am
by seanadams
One more little update and then I have to go to bed:
after taking noapic and pci=noacpi out of my lilo.conf, I *almost* get video again. Shows VERY briefly in xawtv, and it's all corrupted - mostly black with a few lines of garbage across the top.
So the problem does not seem to be specific to zoneminder. I now get the crash within just 2-3 seconds or so if I just run xawtv.
And zoneminder still gives the error about shmem not initialized by capture daemon - there's no video in zm now.
Posted: Tue Aug 31, 2004 4:13 pm
by Doug
Since you started crashing quicker with a faster system, my guess is that there is something stomping on the driver data used by the bttv( since ZM and xawtv both crash it ). Pulling out any non-essential kernel modules would be where I'd start.
But, if you have an open partition, why not try installing from the LiveCD and see if that too bombs out. If it doesn't, then you might look at the modules being loaded in your manual installation and drop out the ones not needed to run video and go from there.
Posted: Tue Aug 31, 2004 6:40 pm
by seanadams
Thanks Doug. Now I'm trying to install the livecd and I'm getting an oops just after swap is activated.
"Unable to handle kernel paging request at virtual address f9acc0d8"
I won't retype all the trace info unless it's needed, but it appears to be in kobject_register, inside bus_add_driver.
After the Oops, it prints
/etc/rc.d/rc.modules: 7962 Segmentation fault [.....]
bttv: driver version 0.9.12 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
...and then it hangs there.
One thing that was interesting is while it was hung on this screen, my VGA timing wigged out a bit for a few minutes as I was typing this message, then it stabilized again.
I tried diabling the bios settings "assign IRQ for VGA" as suggested in another thread, and also "assign IRQ for USB". Still the same Oops.
Posted: Tue Aug 31, 2004 6:57 pm
by seanadams
'twas the SCSI module.
"livecd noscsi" boots ok. Installing...
Posted: Tue Aug 31, 2004 7:38 pm
by Doug
yea, there are some people using Knoppix who also have/had SCSI booting problems. You still can't beat a SCSI bus IMO but it appears to be somewhat problematic at device detection time.
Hopefully, the LiveCD build will shed some light on your manual build...
And BTW, it's a small world. In one of your last replies, there was a SIG mentioning the SlimDevice. I'm they "Doug" who put you in touch with the plastics guys back when you were case-less. :-) From the EE-Times article, it looks like things are going well for the project. Congratulations.
Posted: Tue Aug 31, 2004 7:39 pm
by seanadams
LiveCD installed an booted okay but appears to have the same problem as my 10.0-based install.
zoneminder is reporting shared mem not initialized by capture daemon
If I doubleclick the tvtime icon on the desktop, a black window appears for a 1/10 sec and then goes away.
If I run xawtv, there is a bunch of garbage lines across the screen (not even in a window) and then the system reboots.
Posted: Tue Aug 31, 2004 8:16 pm
by Doug
hmmm, well, the next thing I would shoot for is removing the bttv driver and capture card from the system and see if a USBcam will also cause the problem. Granted, it would likely use the CPIA drivers but it would still be exercising the graphics system. And you still get to fiddle with ZoneMinder with the USBcam device.
If the USBcam causes the problem too, then it could be a graphics driver issue. If it's not the problem then it's going to be the bttv stuff and we'll have to start looking at all the bttv driver options.
From your first post, I notice that one of your bt878's is sharing IRQ-5 with your Mobo sound card. I'd try to clear this or atleast try one of the middle ports/channels( 1 or 2 ) since I'm not sure what IRQ channel 0 would be( 5 or 12 ).
Posted: Tue Aug 31, 2004 8:29 pm
by seanadams
don't have a usb cam handy...
I'm trying a different graphics card - the card I had in there was a CrapTastic(tm) $19 AGP card. Will try an ATI pci card from another system.
Will try shutting off sound in the bios
Memory Issues?
Posted: Tue Aug 31, 2004 8:50 pm
by floyd_2
I noticed in your original post that you had 1GB of memory on your machine, but only seemed to be mounting 500MB of swap. I could be wrong there. If it is the case, you might try upiing your swap partition to 2-3GB as a start, and then perhaps increasing shmmax depending on what its set at currently. You might also try dropping your physical memory just in case mandrake is having any troubles addressing 1GB.
Ive installed LiveCD with 256MB and 394MB RAM using around 800MB - 1000MB swap with no probs. I usually allocate swap at a rate of 2.5 - 3 times physical memory.
btw - I also needed to use the NOUSB switch in conjunction with NOSCSI when I installed LiveCD.
Floyd
Posted: Tue Aug 31, 2004 9:18 pm
by seanadams
the plot thickens....
I tried swapping out the vga card, and now the system does not crash when I run xawtv.
It is trying to display some kind of video signal but it's all mangled in the window... a bunch of flickering lines acting like they're out off sync or misaligned in memory. it is definitely some sort of signal from the camera because it responds to light/dark when I move the camera, and the window turns blue when I unplug the camera.
Same thing happens with both my livecd-based setup and my 10.0 installation. What really odd here is that I'm basically back to my original setup (same kernel etc) where the card was once almost working (albeit with crashes).
I called iTuner support and they didn't have any ideas. So I'm driving up to Fremont now to get the card replaced. The card is the ONLY common denominator in all of these different setups I've tried.
Posted: Tue Aug 31, 2004 10:32 pm
by Doug
good to hear you got it down to just a junky video output. It sounds alot like what I was getting with they cheapo HarborFreight camera I've been messing with. I can now get an image from Xawtv but I think it only started working after I ran "mplayer /dev/video0" to see if it would display the video stream. When I killed xmplayer, xawtv changed how it displayed the video and I tweaked the brightness and contrast to see my night vision B/W image. I still can't get ZM to display the video but I had thought the camera was bad before this.
I had checked out my KWorld capture card( one bt878 w/four ports ) by connecting the VideoOut signal from a VGA->TV(RCA) converter to cards inputs one at a time. I saw blue in ZM and then I saw my servers display in ZM.
Once you get your new card, if the same video is displayed, it's probably a setting or two that's causing the problem. I know that I had to specify the H and V size exactly before getting the signal to stop rolling and stabilize.
I also used the STOP and START link on the ZM console to switch between using the desktop TVTime or xawtv applications and ZM.
Posted: Tue Aug 31, 2004 10:49 pm
by seanadams
It looks like it was a bad framegrabber card.
I replaced the spectra8 and now suddenly I am getting beautiful full motion color video in xawtv, with no more crashes (so far).
Still no signal in ZM yet but I think that's a simpler matter so I'm going to fiddle around a bit more...
Posted: Tue Aug 31, 2004 11:09 pm
by Doug
good news. Hopefully you're well on your way now. :-)
