Hi all,
this is my first post - so take it easy.
Installed live cd, with v1.19.1 and fitted clone 4 port card.
set options in /etc/modprobe.conf
options i2c-algo-bit bit_test=1
so bttv would load faster
using generic cardtype=0 for bttv module
for some reason, zoneminder only displays a blue screen - no image. ( is this what is called a white out screen ? )
anyway, when I fire up xawtv, this displays the camera image ok and then suddenly, the zoneminder live feed, works ! ( for some reason, I need to always start xawtv before I can use zoneminder )
Any ideas. ( linux version from livecd is mandrake 10 ) I only have one colour ccd camera fitted.
Regards
Doug.
pico2000 ( conexant fusion 2000)
How do you access other channels/inputs?
I just got one pico2000 for testing but I still have no cameras to test it
Anyway, "modprobe bttv" worked out-of-the-box, but using mplayer -tv driver=v4l2 tv:// I can just open one channel/input, how do I use other 3?
