"No part content type" error
addeej
Post by addeej »
I have been using ZoneMinder without any problems for a few months now, however, I have just tried to get apache to run in SSL mode to increase the security over the internet. Since I changed the server over to use SSL, I have been getting a "No part content type" error whenever I try and view a stream. I have tried changing back to non-ssl mode, but I still get the same error - I have clearly stuffed something up somewhere! Everything else is working fine, and I can still view everything in still picture mode.
Does anyone know what I may have done wrong? I have tried googling the error message with a rather suprising 0 results!! :x
Any help would be appreciated
zoneminder
Site Admin
Post by zoneminder »
Where do you see the error appearing?
If it's from Cambozola have you changed the version you are using? Normally this can be fixed by using nph-zms instead on zms in the ZMS_PATH option but it isn't usually related to SSL. In fact I'm not sure how you'd get SSL to work really as you'd be sending an encrypted stream into Cambozola wouldn't you?
Phil,
