No streaming in IE, Mozilla OK
cxf
Post by cxf »
Hi there,
I've got my first build of ZoneMinder (1.19.4) up & running on my fedora 2 box OK :- "watching a stream" with Mozilla is fine, but with Internet Explorer, all I see is stills, with no option to select "stream" (i.e. the link is missing in the watch window)
I've got cambozola v0.60 which appears to run OK. It's installed in /var/www/cgi-bin (and I've also tried it in /var/www/html/zm with the same results) but in the watch window there's no mention or hint of cambozola at all! (I mean no mention of cambozola when viewing the page source)
No errors/clues in any logs either!
I've tried zms and the nph-zms with the same (non) results!
cxf
Post by cxf »
Fixed!
The "Path" combinations I'd been trying for cambozola were all wrong - then I read the hint :roll: , and left it as "cambozola.jar" all working now! D'oh!
stoffell
Post by stoffell »
hi,
good to see it works now.. just curious, do you also have 'performance' issues with cambozola ?
If I view 4 camera's in the montage view, my cpu (of the client computer with windows XP) is going up to the 100% usage..
If I view the same montage view with firefox (on the same pc) it only goes to about 45-50%..
Using native motion jpeg does help a bit..
cxf
Post by cxf »
stoffell wrote:hi,
I only have one camera at present (just testing with a USB webcam) so I haven't even seen the montage view yet :wink:
Chris.
