zoneminder wrote:Hi,
The update from .4 to .5 does change the event path from
/var/www/html/zm/events/cameraName
to
/var/www/html/zm/events/cameraId
though the cameraName path is left there as an alias, though nothing should be using it. It's possible that if zmupdate fell over during the database update then this part did not complete either. Then probably zmaudit came alog and hoovered up stuff fromt he DB that didn't have a corresponding event path. I'm surprised zmupdate didn't work with your root user though as that should have privileges for everything. The ZM users only have access and not structural modification privileges.
Unfortunately I don't have a machine spare that I can dedicate to the liveCD version so I can't really tell for sure what might have happened. Any other information you can provide might help track things down.
Cheers,
Phil,
When I can get back to it, I'll see if I can figure out how to backup the dbase and then rebuild the v1.19.1 system to retest this. Since all the original v1.19.1 build stuff is untouched on the HD, I figure/hope backing up the dbase, starting with a fresh schema, and running "make install" from the orginal build would get me back to a fresh v1.19.1.
Then I can setup the cameras and force a few events so I can try the upgrade steps again to see if the migration faults were cockpit errors( likely ) or script/instructional errors.
Phil, when would you want this info? I'm taking the weekend off and so I wouldn't be able to get to it til next week.
