Page 1 of 1
low frame rate
Posted: Thu Sep 30, 2004 2:41 am
by radon
Is there any place I can set the frame rate? I'm using zm-1.19.5. I'm only getting a 2.7fps & is too low. What can I do to increase the frame rate? Thanks.
Higher Framerate
Posted: Thu Sep 30, 2004 8:06 am
by ma77hias
My experience with different Zoneminder systems, would suggest that it is not Zoneminder which is limiting your framerate, but your general system setup. Like:
-what camera are you using LAN, USB, Wireless or are you using a capture card?
-resolution of cam ?
-CPU, RAM ?
Posted: Thu Sep 30, 2004 8:11 am
by radon
I'm using a video capture card.
Not sure abt the camera resolution.
System specs, a amd xp 1900+ with 256M ram
