I am trying to install Zoneminder on a box running fedora core 2. If I run the configure script, it says" no accaptable C compiler found in $PATH", although I installed GCC with yum. Checking the configure.log does not help much as it only repeats this output.
The complete command I run is:
./configure --with-mysql=/usr/bin --with-webdir=/bigboy/website/www/html/zm --with-cgidir=/bigboy/website/www/cgi-bin --with-ffmpeg=/usr/bin --with-mp3lame=/usr/lib
Any suggestions?
Many thanks,
Paul
Problem installing Zoneminder
- zoneminder
- Site Admin
- Contact:
Is gcc actually installed on your path? In other words if you do
do you get something back?
Also bear in mind that you need a C++ compiler. So it's actually g++ you need to test but I think gcc never comes without g++ anyway.
Phil,
gcc -v
Phil,
c++ compiler
From my expierience with FC2 you also need a lot of the devel packages and not just the plain ones for zoneminder
Problem installing Zoneminder continued
Dear Phil,
If I do I get back "command not found". When I do I get so many different directories that I am confused about the right directory to set the path to. Any suggestions on where fedora puts gcc?
Many thanks,
Newbie Paul
If I do
gcc -v
locate gcc
Many thanks,
Newbie Paul
No more problems with installl on FC2
Dear Phil,
Got everything running now on fc2. Thanks anyhow!
Paul
Paul
