Distorted image
LuChris
Distorted image
Post by LuChris »
I finally got ZM working with the min requirements. I do not have clear images. Image.
How can i solve this?
thanks
lazyleopard
Post by lazyleopard »
Looks like there's no video signal on Cam1, while Cam2 and Cam3 aren't agreeing with the settings somehow... Try setting Cam1 to None and then stopping and re-starting zoneminder.
To give any useful help we'd probably need to know what video card you were using and what settings you've got for the camera inputs, particularly those from the Monitor->Source panels.
If you have one of the Bt8x8 cards that share one Bt8x8 chip between multiple inputs then make sure they're all using the same format, pallette and resolution...
Rick Hewett
