ZoneMinder failing to connect to mysql
w@tcher
Post by w@tcher »
Just installed everything it all appears to been installed ok. However when I try and connect to my webserver I receive the following message
Warning: mysql_pconnect(): Client does not support authentication protocol requested by server; consider upgrading MySQL client in /usr/local/apache2/htdocs/zm/zm_db.php on line 21
Could not connect to database: Client does not support authentication protocol requested by server; consider upgrading MySQL client
Is there something I am missing. PHP was built with mysql support? Is there something that I can do to check connectivity.
perl zmconfig.pl -noi connects to mysql fine...
fernando
Post by fernando »
is php_mysql installed?
what linux release you have?
Fernando
w@tcher
Post by w@tcher »
Sorry -I am running Suse 9.1
I installed PHP 4.3.9 from the source with:
./configure --with-apxs2=/usr/local/apache2/bin/apxs --with-mysql
I am also running Apache2.
fernando
Post by fernando »
iam sorry i dont have idea about suse..
that error came whitout php-mysql or when the mysql users dont have a host. like zm@localhost.
Fernando
w@tcher
Post by w@tcher »
doing a bit more reading problem may be because I have installed mysql 4.1.5 has anyone else got a working system based on mysql 4.1.5?
Is it worth downgrading to 4.0?
w@tcher
Post by w@tcher »
downgraded to 4.0 - no problems at all.....
thanks
