Page 1 of 1
Blank zm.php page and mysql_pconnect() undefined function.
Posted: Sat Oct 16, 2004 6:18 pm
by Dirky
I've just installed zoneminder on Fedora core 2. (apache 2.0.49)
However when I go to the zm.php page it is blank. The source of the page is totally blank to.
Looking at the httpd error log I see:
[client 192.168.1.27] PHP Notice:  import_request_variables(): No prefix specified - possible security hazard in /var/www/html/zm/zm.php on line 21
[client 192.168.1.27] PHP Fatal error:  Call to undefined function:  mysql_pconnect() in /var/www/html/zm/zm_db.php on line 21
I've checked my php (4.3.4) and it shows:-
Configure Command  './configure' '--host=i386-redhat-linux' '--build=i386-redhat-linux' '--target=i386-redhat-linux-gnu' '--program-prefix=' '--prefix=/usr' '--exec-prefix=/usr' '--bindir=/usr/bin' '--sbindir=/usr/sbin' '--sysconfdir=/etc' '--datadir=/usr/share' '--includedir=/usr/include' '--libdir=/usr/lib' '--libexecdir=/usr/libexec' '--localstatedir=/var' '--sharedstatedir=/usr/com' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--cache-file=../config.cache' '--with-config-file-path=/etc' '--with-config-file-scan-dir=/etc/php.d' '--enable-force-cgi-redirect' '--disable-debug' '--enable-pic' '--disable-rpath' '--enable-inline-optimization' '--with-bz2' '--with-db4=/usr' '--with-curl' '--with-exec-dir=/usr/bin' '--with-freetype-dir=/usr' '--with-png-dir=/usr' '--with-gd' '--enable-gd-native-ttf' '--without-gdbm' '--with-gettext' '--with-ncurses' '--with-gmp' '--with-iconv' '--with-jpeg-dir=/usr' '--with-openssl' '--with-png' '--with-pspell' '--with-regex=system' '--with-xml' '--with-expat-dir=/usr' '--with-dom=shared,/usr' '--with-dom-xslt=/usr' '--with-dom-exslt=/usr' '--with-xmlrpc=shared' '--with-pcre-regex=/usr' '--with-zlib' '--with-layout=GNU' '--enable-bcmath' '--enable-exif' '--enable-ftp' '--enable-magic-quotes' '--enable-safe-mode' '--enable-sockets' '--enable-sysvsem' '--enable-sysvshm' '--enable-track-vars' '--enable-trans-sid' '--enable-yp' '--enable-wddx' '--with-pear=/usr/share/pear' '--with-imap=shared' '--with-imap-ssl' '--with-kerberos' '--with-ldap=shared' '--with-mysql=shared,/usr' '--with-pgsql=shared' '--with-snmp=shared,/usr' '--with-snmp=shared' '--enable-ucd-snmp-hack' '--with-unixODBC=shared,/usr' '--enable-memory-limit' '--enable-bcmath' '--enable-shmop' '--enable-calendar' '--enable-dbx' '--enable-dio' '--enable-mcal' '--enable-mbstring' '--enable-mbstr-enc-trans' '--enable-mbregex' '--with-apxs2=/usr/sbin/apxs'
Any ideas where I am going wrong?
Many thanks,
Mike
Posted: Sat Oct 16, 2004 7:03 pm
by zoneminder
Your php is defined as supporting mysql in shared mode. This means that if it can find the mysql shared library object, mysql.so, in the php library directory, in my case /usr/lib/php4, then it will support mysql, otherwise it won't.
So if you don't have a mysql.so you will either need to build one or find one somewhere. It will need to match your php and mysql versions though. If you are using a package based distribution then try searching for a php-mysql package which I think may contain it.
Phil,
Posted: Sat Oct 16, 2004 7:37 pm
by Dirky
Hi Phil,
you are spot on the mark!
I did a
yum install php-mysql.i386
And now I can connect to it.
many thanks!
Mike
