Minimized of CPU load
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
oskin
Post by oskin »
I think it is possible to make so that zma could parse not each frame received from zmc, but, for example, each fifth frame (is customized), but at active alarm to save it is necessary each frame. IMHO it will considerably lower loading system in a waiting mode.
zoneminder
Site Admin
Post by zoneminder »
You can't do this exactly but you can set the capture rate to a low FPS but then set ZM_NO_MAX_FPS_ON_ALARM to on which means it will ignore this limit when an alarm is detected. It's not exactly the same thing but not vastly different.
Phil,
