If I wanted to capture 8 640x480 color video streamsw/ motion detection at a reasonable rate with quick response from the web interface which setup would you choose?
-Athlon 64
-P4 3+GHz +HT?
-2 individual machines? 1 to capture, one to stream to clients?
-Dual processor machine? Pehaps have apache set to use processor 2 while the capture daemon uses processor 1?
any other ideas?
Fast System for ZM?
- lazyleopard
- securiteaze
- zoneminder
- Site Admin
- Contact:
I'm not sure what you mean by multi-processor aware. Generally it is the kernel that deals with the scheduling.
However as mentioned aboive, as ZM consists of several daemons all running independently there is a good chance that the kernel will tend to distribute them around the processors to make the most of the available resources.
But I've never explitictly tested it (not having a mutli-processor machine to play with
Phil
securiteaze, or anyone else,
any evidence of Intel's HTT http://en.wikipedia.org/wiki/Hyperthreading (hyperthreading) improving performance? I know current gen p4's phased out HTT.
From 7000 feet in Colorado
