No montage link???
direwolf
No montage link???
Post by direwolf »
Ok, I think I have most things set up and it all seems to be running.
I have added one monitor which is showing up all green but there is no montage link on the page to see the images??
EDIT: Oh and this is showing in the zmdc.log
Starting pending process, zmfilter.pl
'zmfilter.pl' started at 04/10/23 21:59:52
'zmfilter.pl' starting at 04/10/23 21:59:52, pid = 11162
Can't locate MIME/Entity.pm in @INC (@INC contains: /usr/lib/perl5/5.8.0/i386-linux-thread-multi /usr/lib/perl5/5.8.0 /usr/lib/perl5/site_perl/5.8.0/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.0 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.0/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.0 /usr/lib/perl5/vendor_perl /usr/lib/perl5/5.8.0/i386-linux-thread-multi /usr/lib/perl5/5.8.0) at /usr/local/bin/zmfilter.pl line 87.
BEGIN failed--compilation aborted at /usr/local/bin/zmfilter.pl line 87.
'zmfilter.pl ' crashed at 04/10/23 21:59:53, exit status 2
zoneminder
Site Admin
Post by zoneminder »
You only get a montage link when you have more than one camera, that's by design as you can't really have a montage of one. You can edit the console php file if that's not what you want.
Check the README file (or search the forums) for how to install the MIME::Entiry perl module.
Phil,
direwolf
Post by direwolf »
Ok I installed MIME and its dependancies but I still get the error
I checked I MIME is in the 5.8.3 directory where Zomeminder is looking in the 5.8.0 directory. How can I fix this?
/usr/lib/perl5/site_perl/5.8.3/MIME/Entity.pm
Also is it possible to stop this message from apprearing in my messages log as it filled up to 100Meg in size while I was testing for a few minutes
Oct 24 16:23:14 router zms[9117]: INF [Debug Level = 0, Debug Log = ]
Oct 24 16:23:14 router zms[9118]: INF [Debug Level = 0, Debug Log = ]
Oct 24 16:23:24 router zms[9132]: INF [Debug Level = 0, Debug Log = ]
Oct 24 16:23:24 router zms[9131]: INF [Debug Level = 0, Debug Log = ]
zoneminder
Site Admin
It looks to me like you have two versions of perl installed. The script is looking in a 5.8.0 tree and you have installed it into a 5.8.3 tree.
To get rid of the zms debug you can edit zms.cpp and add the line
zm_dbg_level = -1;
just after the zm_dbg_name assignment. Then rebuild and reinstall etc.
Phil,
