Genreate Video fails??
direwolf
Post by direwolf »
When I try and generate a video from an event I get a message "Video Generation Failed!" but there doesn't seem to be anything in the logs.
Where should I start looking to find out what is wrong??
zoneminder
Site Admin
Post by zoneminder »
There should be something in zmvideo.log, if you can find it (start by looking in /tmp unless you've defined it to be elsewhere), post what it says. There is an issue where some people don't seem to be able to generate low framerate video.
Phil,
direwolf
Post by direwolf »
ahh, that was my problem.
I had no zmvideo.log
Once I created it and set the permissions I was able to create a video no problems. :)
zoneminder
Site Admin
It sounds like there is a permissions problem on your log directory itself. If ZM can't create logs in there you may find various things fail in mysterious ways.
Phil,
