configuration problems
Posted: Mon Oct 25, 2004 10:18 am
I tried to install Zoneminder 1.19.5 on Fedora core 1
I'm using bttv video capture card with 4 in , but i use only the first one in .
It works with xawtv but i can't see zone images on web console
I got the following errors :
Oct 25 10:48:54 outerspace kernel: bttv: Bt8xx card found (0).
Oct 25 10:48:54 outerspace kernel: PCI: Found IRQ 10 for device 00:0b.0
Oct 25 10:48:54 outerspace kernel: PCI: Sharing IRQ 10 with 00:0b.1
Oct 25 10:48:54 outerspace kernel: PCI: Sharing IRQ 10 with 00:10.2
Oct 25 10:48:54 outerspace kernel: bttv0: Bt878 (rev 17) at 00:0b.0, irq: 10, la tency: 32, mmio: 0xee001000
Oct 25 10:48:54 outerspace kernel: bttv0: using: BT878( *** UNKNOWN/GENERIC **) [card=0,autodetected]
Oct 25 10:48:54 outerspace kernel: i2c-core.o: adapter bt848 #0 registered as ad apter 0.
Oct 25 10:49:10 outerspace kernel: bttv: readee error
Oct 25 10:49:10 outerspace kernel: bttv0: using tuner=-1
Oct 25 10:49:26 outerspace kernel: bttv0: i2c: checking for MSP34xx @ 0x80... no t found
Oct 25 10:49:42 outerspace kernel: bttv0: i2c: checking for TDA9875 @ 0xb0... no t found
Oct 25 10:49:58 outerspace kernel: bttv0: i2c: checking for TDA7432 @ 0x8a... no t found
Oct 25 10:49:58 outerspace kernel: bttv0: registered device video0
Oct 25 10:49:58 outerspace kernel: bttv0: registered device vbi0
Oct 25 11:10:19 outerspace gdm(pam_unix)[4050]: session closed for user root
Oct 25 11:10:27 outerspace gdm(pam_unix)[4050]: session opened for user root by (uid=0)
Oct 25 11:10:27 outerspace xinetd[4609]: warning: can't get client address: Tran sport endpoint is not connected
Oct 25 11:12:35 outerspace zmfix[4823]: INF [Debug Level = 0, Debug Log = ]
Oct 25 11:12:35 outerspace zmfix[4823]: INF [Resetting permissions on /dev/video 0 to 20606]
Oct 25 11:12:39 outerspace zmc-d0[4846]: INF [Debug Level = 0, Debug Log = ]
Oct 25 11:12:39 outerspace zmc-d0[4846]: ERR [Can't run query: Unknown column 'B rightness' in 'field list']
--------zmaudit.log
DBD::mysql::st execute failed: Unknown column 'M.EventPrefix' in 'field list' at /usr/local/bin/zmaudit.pl line 299.
Can't execute: Unknown column 'M.EventPrefix' in 'field list' at /usr/local/bin/zmaudit.pl line 299.
--------zmdc.log
Starting pending process, zmx10.pl -c start
'zmx10.pl -c start' started at 04/10/25 11:43:51
'zmx10.pl -c start' starting at 04/10/25 11:43:51, pid = 8038
Can't locate X10/ActiveHome.pm in @INC (@INC contains: /usr/lib/perl5/5.8.3/i386-linux-thread-multi /usr/lib/perl5/5.8.3 /usr/lib/perl5/site_perl/5.8.3/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.2/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.1/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.0/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.3 /usr/lib/perl5/site_perl/5.8.2 /usr/lib/perl5/site_perl/5.8.1 /usr/lib/perl5/site_perl/5.8.0 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.3/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.2/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.1/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.0/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.3 /usr/lib/perl5/vendor_perl/5.8.2 /usr/lib/perl5/vendor_perl/5.8.1 /usr/lib/perl5/vendor_perl/5.8.0 /usr/lib/perl5/vendor_perl) at /usr/local/bin/zmx10.pl line 165.
BEGIN failed--compilation aborted at /usr/local/bin/zmx10.pl line 165.
'zmx10.pl -c start' crashed at 04/10/25 11:43:52, exit status 2
-----------zmwatch.log
Watchdog starting at 04/10/25 11:42:34
Watchdog pausing for 30 seconds
Can't get shared memory id '2053971971': No such file or directory
Any help appreciated , thanks in advance
regards
Stefano
--------zmaudit.log
--------zmdc.log
regards
Stefano
