Page 1 of 1
purgewhenfull
Posted: Thu Nov 04, 2004 7:29 pm
by curtishall
I know there's a filter for purgewhenfull, which I can set to automagically delete events. Is there a way to run the filter every say....hour to so to delete the events...ie - automatic not user submitted..
thanks
Posted: Thu Nov 04, 2004 7:56 pm
by rdmelin
I believe saved filters are reloaded every 5 min. by default. So you just need to select the purgewhenfull filter and click the save link. Then be sure the "Automatically delete all matches: " box is checked.
Posted: Thu Nov 04, 2004 11:01 pm
by zoneminder
That's correct. Anytime you check an 'automatically' do something box it will be run every few minutes.
Phil,
