ZM-Logs redirect to syslog
Posted: Tue Nov 09, 2004 9:36 am
Dear all,
as I like to get all logging centralized I've wrote a little (dirty) script to parse ZMs internal logs like 'zmfilter.log' to syslog. In case someone might find this usefull:
Use it at your own risk
Uli
#!/bin/bash
# really dirty hack to redirect ZMs internal logs to syslog
# enviroment : Console
# Depends on : logger, tail, wc, grep
# written : 2004-11-08
# last modified : 2004-11-09
# Author : Uli Wachowitz
# Status : 0.0.1
# define your logs
LOGDIR="/tmp"
LOGFILE="
zmaudit.log
zmdc.log
zmfilter.log
zmpkg.log
zmwatch.log
### no changes beyond this line ###
# check if dependancies are ok, otherwise exit
DEPEND="
logger
tail
wc
grep
for i in $DEPEND; do
if [ "$(which $i)" == "" ]; then
echo "'$i' not found, exiting"
exit
fi
done
# create a new, renamed link to the logger binary to avoid conflicts if we kill it
# and there is another logger already running
[ ! -x /usr/bin/zm_logger.bin ] && ln -s $(which logger) /usr/bin/zm_logger.bin
LOGGER_BIN=$(which zm_logger.bin)
# check if the linking was successfull, otherwise exit
if [ "$LOGGER_BIN" == "" ]; then
echo "'/usr/bin/zm_logger.bin' does not exist, exiting"
exit
fi
StartLogging() {
# check if this is the only instance of this tool. If there is another one
# alreday running, exit
if [ "$(ps -A| grep zm_logger.bin | wc -l)" -gt "0" ]; then
echo
echo "ERROR: There is another 'zm_logging' active"
echo "Use '$0 stop' first to stop all running instances to avoid problems"
echo
exit
fi
# here we go
cd $LOGDIR
# ugly, ugly, ugly
# this will create 2 processes of 'zm_logger.sh' and 1 process of 'zm_logger.bin'
# for each of the monitored logfiles
# But this is the only way to get logger write the names of the logfiles
# in front of the entries
# Nonetheless, the impact on sytemload is quite small
for i in $LOGFILE; do
nohup `tail -f -n 0 $i | $LOGGER_BIN -t $i --` &
done
$LOGGER_BIN "zm_logger.sh started"
return
Usage() {
echo
echo "USAGE: $0 [start|stop]"
echo
exit
return
case $1 in
stop) $LOGGER_BIN "zm_logger.sh stopped"
killall -9 zm_logger.bin
killall -9 zm_logger.sh
start) StartLogging
*) Usage
esac
Uli
