Page 1 of 1
Spiders Can you help
Posted: Tue Nov 16, 2004 5:45 pm
by wheelbarrow
Hi Guys,
Please take a look at this and see what you think.
http://www.ptu.biz/video/video.mpg
Any one got any good ideas on how i can prevent this.
Regards
Paul
Posted: Tue Nov 16, 2004 6:03 pm
by lazyleopard
Ummm... Can't view the mpg (inadequate software this end), but I'm guessing you've got small creepy-crawlies in front of your camera?
I get quite a few false-alarms from flies and spiders.
Only solution I can think of is to place some creepy-crawly repellant (moth-repellant might do) near the camera and hope.
Re: Spiders Can you help
Posted: Tue Nov 16, 2004 8:48 pm
by 2tomcats
Yes. that looks exactly like my problem
I'm having probs with those little invaders for years. I've tried lots of things including chemical weapons. Nothing helps. The only solution I have is to use a besom or so and start a little hunt for them.
Sorry
Uli
Posted: Wed Nov 17, 2004 1:09 pm
by zoneminder
If your spiders are haning off your camera then you could try greasing the outside and seeing it that puts them off. If they are just dangling in front your are a bit stuck unless you put a big hood on, or a large fan to blow them away!
Phil,
