Hi.
It seems like i have alot of streaming media server deamons running all the time (zms)
Why is that? I use Netscape view the events.
//Per
Several streaming media server deamons.
- zoneminder
- Site Admin
- Contact:
Re: Several streaming media server deamons.
Hi Per,
Can you tell me what distribution you are running ZM on? I know that with RH9 there seem to be some problems with zms processes not being killed properly, I think mostly due to apache2.
Cheers,
Phil,
Cheers,
Phil,
Hi.
I do run RH9.
Can you please make a suggestion for a distribution that works
without problems
//Per
I do run RH9.
without problems
//Per
- tech_fixer
Per:
Look at the FAQ section go to the entry that reads:
Why does ZoneMinder on RedHat 9 leak memory and crash my machine?
Regards,
Jose Rodriguez
Regards,
Jose Rodriguez
