Most people on this forum reports zma going up when there's an event and runs low when it's idle, but mine sits at 30-40% when there's no event at all. I also varied the Max FPS from 5-30 and it makes no difference. The values below are from a Max FPS of 5. zmc and zma take up most of the CPU with mysqld occassionally jumping in there at 99.9% CPU load and lasting about 1-2 seconds.
I'm not seeing the memory leak in Apache as others have reported so I don't think that's the issue. Memory usage stays pretty much consistent. swap space is not even been used so I know everything is sitting in RAM. And I'm taking really small photos (320x240) at 5 FPS.
My server setup is as follows:
1.3Ghz C3
256MB RAM DDR
160GB HD
RedHat 8
RGB24 input
BT878A 4 channel capture card. Only 1 channel is in Modect, the other 3 are currently set to none (not capturing).
At this CPU %, I don't see how I can even get 2 out of 4 channels running on this box.
Anyone else experiencing a similar problem? Anything else I can try?
3:28pm up 7:05, 3 users, load average: 1.45, 1.13, 0.93
70 processes: 67 sleeping, 3 running, 0 zombie, 0 stopped
CPU states: 74.3% user, 2.1% system, 0.0% nice, 23.4% idle
Mem: 255656K av, 229492K used, 26164K free, 0K shrd, 31100K buff
Swap: 1052248K av, 0K used, 1052248K free 129780K cached
PID USER PRI NI SIZE RSS SHARE STAT %CPU %MEM TIME COMMAND
16549 apache 24 0 24552 23M 23600 S 37.2 9.6 43:18 /usr/local/bin/zma -m 1
13823 apache 15 0 28740 24M 23600 R 23.8 9.6 34:31 /usr/local/bin/zmc -d 0
13148 root 15 0 5940 5940 5520 S 1.7 2.3 2:53 /usr/sbin/httpd
23414 root 15 0 1060 1060 820 R 0.7 0.4 0:00 top -c
11 root 15 0 0 0 0 SW 0.1 0.0 0:01 kjournald
1693 mysql 15 0 7028 7028 2620 S 0.1 2.7 0:10 /usr/libexec/mysqld --defaults-file=/etc/my.cnf --basedir=/usr --datadir=/var/lib/mysql --user=
1 root 15 0 460 460 408 S 0.0 0.1 0:04 init
2 root 15 0 0 0 0 SW 0.0 0.0 0:00 keventd
3 root 34 19 0 0 0 SWN 0.0 0.0 0:00 ksoftirqd_CPU0
4 root 15 0 0 0 0 SW 0.0 0.0 0:00 kswapd
5 root 25 0 0 0 0 SW 0.0 0.0 0:00 bdflush
6 root 15 0 0 0 0 SW 0.0 0.0 0:00 kupdated
7 root 25 0 0 0 0 SW 0.0 0.0 0:00 mdrecoveryd
67 root 15 0 0 0 0 SW 0.0 0.0 0:00 khubd
225 root 15 0 0 0 0 SW 0.0 0.0 0:00 kjournald
503 root 16 0 536 536 448 S 0.0 0.2 0:00 syslogd -m 0
507 root 15 0 432 432 376 S 0.0 0.1 0:00 klogd -x
524 rpc 15 0 528 528 452 S 0.0 0.2 0:00 portmap
543 rpcuser 18 0 728 728 636 S 0.0 0.2 0:00 rpc.statd
655 root 20 0 1428 1428 1276 S 0.0 0.5 0:07 /usr/sbin/sshd
669 root 15 0 924 924 788 S 0.0 0.3 0:00 xinetd -stayalive -reuse -pidfile /var/run/xinetd.pid
730 root 15 0 2244 2244 1660 S 0.0 0.8 0:00 sendmail: accepting connections
742 smmsp 15 0 2004 2000 1536 S 0.0 0.7 0:00 sendmail: Queue runner@01:00:00 for /var/spool/clientmqueue
753 root 15 0 428 428 376 S 0.0 0.1 0:00 gpm -t imps2 -m /dev/mouse
773 root 15 0 616 616 540 S 0.0 0.2 0:00 crond
804 xfs 15 0 3260 3260 880 S 0.0 1.2 0:00 xfs -droppriv -daemon
822 daemon 15 0 524 524 464 S 0.0 0.2 0:00 /usr/sbin/atd
832 root 16 0 388 388 336 S 0.0 0.1 0:00 /sbin/mingetty tty2
833 root 16 0 388 388 336 S 0.0 0.1 0:00 /sbin/mingetty tty3
834 root 16 0 388 388 336 S 0.0 0.1 0:00 /sbin/mingetty tty4
835 root 16 0 388 388 336 S 0.0 0.1 0:00 /sbin/mingetty tty5
836 root 16 0 388 388 336 S 0.0 0.1 0:00 /sbin/mingetty tty6
895 root 16 0 388 388 336 S 0.0 0.1 0:00 /sbin/mingetty tty1
1206 root 15 0 1476 1476 1128 S 0.0 0.5 0:00 -bash
1666 root 19 0 1172 1172 1008 S 0.0 0.4 0:00 /bin/sh /usr/bin/safe_mysqld --defaults-file=/etc/my.cnf
3397 root 15 0 1480 1480 1128 S 0.0 0.5 0:00 -bash
10106 root 15 0 1468 1468 1128 S 0.0 0.5 0:00 -bash
13201 apache 15 0 5240 5240 1984 S 0.0 2.0 0:01 /usr/bin/perl -wT /usr/local/bin/zmdc.pl status
13226 apache 15 0 11340 11M 2056 S 0.0 4.4 0:01 /usr/bin/perl -wT /usr/local/bin/zmfilter.pl
13231 apache 15 0 4156 4156 1824 S 0.0 1.6 0:00 /usr/bin/perl -wT /usr/local/bin/zmaudit.pl -d 900 -y
13238 apache 15 0 4656 4656 1896 S 0.0 1.8 0:00 /usr/bin/perl -wT /usr/local/bin/zmwatch.pl
13243 apache 15 0 5800 5800 1904 S 0.0 2.2 0:00 /usr/bin/perl -w /usr/local/bin/zmupdate.pl -c
