No image/video from my Axis 2100
I istalleed zm on Fedora2. I'm using Apache 2.0.52, PHP 4.3.9 and Mysql 3.23.58-9.
I'm not able to view any image and video from Axis 2100. I configured it as:
Host name: http://192.168.1.205
Host port: 80
Host path: /cgi-bin/mjpg/video.cgi
If i run wget -S http:// 192.168.1.205/cgi-bin/mjpg/video.cgi it work fine
This my log files.
zmdc.log:
Server starting at 04/11/23 16:27:59
'zmc -m 1' started at 04/11/23 16:28:03
'zmc -m 1' starting at 04/11/23 16:28:03, pid = 3865
'zmfilter.pl' started at 04/11/23 16:28:03
'zmfilter.pl' starting at 04/11/23 16:28:03, pid = 3869
'zmc -m 1' crashed at 04/11/23 16:28:03, exit status 255
'zmc -m 1' starting at 04/11/23 16:28:03, pid = 3871
'zmc -m 1' crashed at 04/11/23 16:28:04, exit status 255
'zmaudit.pl -d 900 -y' started at 04/11/23 16:28:04
'zmaudit.pl -d 900 -y' starting at 04/11/23 16:28:04, pid = 3875
'zmwatch.pl' starting at 04/11/23 16:28:04, pid = 3880
'zmwatch.pl' started at 04/11/23 16:28:04
'zmupdate.pl -c' started at 04/11/23 16:28:05
'zmupdate.pl -c' starting at 04/11/23 16:28:05, pid = 3884
Starting pending process, zmc -m 1
'zmc -m 1' started at 04/11/23 16:28:09
'zmc -m 1' starting at 04/11/23 16:28:09, pid = 3895
'zmc -m 1' crashed at 04/11/23 16:28:10, exit status 255
/var/log/messages:
Nov 23 16:27:12 localhost zmu[3818]: ERR [Shared memory not initialised by capture daemon]
Nov 23 16:27:12 localhost zms[3822]: INF [Debug Level = 0, Debug Log = ]
Nov 23 16:27:12 localhost zms[3822]: ERR [Shared memory not initialised by capture daemon]
Nov 23 16:27:59 localhost zmfix[3842]: INF [Debug Level = 0, Debug Log = ]
Nov 23 16:28:03 localhost zmc-m1[3865]: INF [Debug Level = 0, Debug Log = ]
Nov 23 16:28:03 localhost zmc-m1[3865]: ERR [Can't gethostbyname(http://192.168.1.205): Operation not permitted]
Nov 23 16:28:03 localhost zmc-m1[3871]: INF [Debug Level = 0, Debug Log = ]
Nov 23 16:28:04 localhost zmc-m1[3871]: ERR [Can't gethostbyname(http://192.168.1.205): Operation not permitted]
Nov 23 16:28:10 localhost zmc-m1[3895]: INF [Debug Level = 0, Debug Log = ]
Nov 23 16:28:10 localhost zmc-m1[3895]: ERR [Can't gethostbyname(http://192.168.1.205): Operation not permitted]
Nov 23 16:28:21 localhost zmc-m1[3899]: INF [Debug Level = 0, Debug Log = ]
Nov 23 16:28:21 localhost zmc-m1[3899]: ERR [Can't gethostbyname(http://192.168.1.205): Operation not permitted]
Nov 23 16:28:41 localhost zmc-m1[3902]: INF [Debug Level = 0, Debug Log = ]
I reduced the size of the captured image because i had an other error of "enogh shared memory" but now it seem to be a camera problem.
Is there anybody can help me?
Host port: 80
This my log files.
zmdc.log:
/var/log/messages:
- zoneminder
- Site Admin
- Contact:
Hi Phil, i follow your istruction but i cannot view video yet.
This my new zmdc.log file:
Server starting at 04/11/24 12:02:45
'zmc -m 1' started at 04/11/24 12:02:48
'zmc -m 1' starting at 04/11/24 12:02:48, pid = 24578
zmc: zm_image.h:192: void Image::CopyBuffer(const Image&): Assertion `width == image.width && height == image.height && colours == image.colours' failed.
'zmfilter.pl' started at 04/11/24 12:02:49
'zmfilter.pl' starting at 04/11/24 12:02:49, pid = 24582
'zmc -m 1' died at 04/11/24 12:02:49, signal 6
'zmc -m 1' started at 04/11/24 12:02:49
'zmc -m 1' starting at 04/11/24 12:02:49, pid = 24585
'zmaudit.pl -d 900 -y' started at 04/11/24 12:02:50
'zmaudit.pl -d 900 -y' starting at 04/11/24 12:02:50, pid = 24588
'zmc -m 1' died at 04/11/24 12:02:50, signal 6
'zmwatch.pl' starting at 04/11/24 12:02:51, pid = 24594
'zmwatch.pl' started at 04/11/24 12:02:51
'zmupdate.pl -c' started at 04/11/24 12:02:51
'zmupdate.pl -c' starting at 04/11/24 12:02:51, pid = 24598
'zmc -m 1' started at 04/11/24 12:02:55
'zmc -m 1' starting at 04/11/24 12:02:55, pid = 24609
'zmc -m 1' died at 04/11/24 12:02:56, signal 6
'zmc -m 1' started at 04/11/24 12:03:06
'zmc -m 1' starting at 04/11/24 12:03:06, pid = 24624
'zmc -m 1' died at 04/11/24 12:03:07, signal 6
Nov 24 12:02:45 localhost zmfix[24555]: INF [Debug Level = 0, Debug Log = ]
Nov 24 12:02:48 localhost zmc-m1[24578]: INF [Debug Level = 0, Debug Log = ]
Nov 24 12:02:49 localhost zmc-m1[24578]: INF [Starting Capture]
Nov 24 12:02:49 localhost zmc-m1[24585]: INF [Debug Level = 0, Debug Log = ]
Nov 24 12:02:49 localhost zmc-m1[24585]: INF [Starting Capture]
Nov 24 12:02:55 localhost zmc-m1[24609]: INF [Debug Level = 0, Debug Log = ]
Nov 24 12:02:56 localhost zmc-m1[24609]: INF [Starting Capture]
Nov 24 12:03:02 localhost zms[24615]: INF [Debug Level = 0, Debug Log = ]
Nov 24 12:03:06 localhost zmc-m1[24624]: INF [Debug Level = 0, Debug Log = ]
Nov 24 12:03:07 localhost zmc-m1[24624]: INF [Starting Capture]
Nov 24 12:03:27 localhost zmc-m1[24627]: INF [Debug Level = 0, Debug Log = ]
Nov 24 12:03:27 localhost zmc-m1[24627]: INF [Starting Capture]
Thank you again
Thank you again
- zoneminder
- Site Admin
- Contact:
This time your problem is that you have defined your monitor to have one images size (maybe 320x240) but your camera is returning an image of a different size (maybe 640x480). You need to do one of three things (1) change your monitor to have the same size as the camera image (2) change the config of your camera to have the same size as the monitor or (3) use the Axis cgi parameters (available in the developer section of Axis.com) to change the image size returned in the path.
Phil,
Phil,
Hi Phil, i changed the image size on the Axis camera. I set to 320*240 pixel, but i have no video and image.
At 640*480 i have shared memory problems, and at 320*240 this my zmdc.log files:
Server starting at 04/11/25 17:08:01
'zmc -m 1' started at 04/11/25 17:08:04
'zmc -m 1' starting at 04/11/25 17:08:04, pid = 8290
'zmc -m 1' died at 04/11/25 17:08:04, signal 8
'zmc -m 1' starting at 04/11/25 17:08:04, pid = 8291
'zmfilter.pl' started at 04/11/25 17:08:04
'zmfilter.pl' starting at 04/11/25 17:08:04, pid = 8294
'zmaudit.pl -d 900 -y' started at 04/11/25 17:08:04
'zmaudit.pl -d 900 -y' starting at 04/11/25 17:08:04, pid = 8298
'zmwatch.pl' starting at 04/11/25 17:08:05, pid = 8302
'zmwatch.pl' started at 04/11/25 17:08:05
'zmupdate.pl -c' starting at 04/11/25 17:08:05, pid = 8307
'zmupdate.pl -c' started at 04/11/25 17:08:05
'zmc -m 1' started at 04/11/25 17:08:09
Can't find child with pid of '8319'
'zmc -m 1' starting at 04/11/25 17:08:09, pid = 8319
Nov 25 17:08:00 localhost zmfix[8267]: INF [Debug Level = 0, Debug Log = ]
Thanks everybody for some conceil
I' m getting image now from 2 Axis 2100 (at 7.39 and 8.57 FPS) but only in still mode and i have no stream.
I have no error in log files and i think to have all plug-in needed to watch video in a browser web (Mozilla in a Fedora 2).
Should i follow some particular configuration?
Is it possible to be a memory problem?
Thanks everybody
fra&fra
Thanks everybody
fra&fra
- zoneminder
- Site Admin
- Contact:
You should be able to watch streams in Mozilla without any kind of plugin. Make sure that Options->Tools is set to either 'auto' or 'yes'.
What do you see instead of the streams, or do you just not get the option to choose it? Also check your bandwidth settings, at low bandwidth streaming can sometimes looks as slow as stills.
Phil,
Phil,
- zoneminder
- Site Admin
- Contact:
There are no browsers that support streaming in MPEG mode natively as far as I know so you have to have it set to jpeg unless you know you have a plugin to handle it.
Currently I know Windows Media Player works as a plugin on IE, and I know that people have got mplayer working with Mozilla but there's no general rule for these so ZM can't autodetect and play MPEG in the page if other plugins are used unless someone tells me about them first so I can add support.
Phil,
Phil,
How I go to inform the password for access to the image?zoneminder wrote:The host name should be just 192.168.1.205 without the http on it. Otherwise you're giving a protocol specifier which doesn't make sense.
Phil,
If I to inform thus: <USER>:<PASS>192.168.1.1/IMAGE.JPG, I will receive an error from inexistent protocol, correct ?
Anyway, i try this way and i receive this errors :
Feb 28 12:55:42 piper zmc_m2[32421]: INF [Debug Level = 0, Debug Log = <none>]
Feb 28 12:55:42 piper zmc_m2[32421]: ERR [Can't gethostbyname(192.168.1.1/IMAGE.JPG): Operation not permitted]
Feb 28 12:55:45 piper zmu[32424]: ERR [Shared memory not initialised by capture daemon]
