Explanation of Alarms, Alerts, and Events
Can somebody explain alarms, alert mode, and events?
So far I've noticed that the system goes to Alarm, then Alert, then Recording, then Idle...I think somebody played a little too much Metal Gear Solid before starting this project
Anyways, I'm a little confused as I have set up a camera with a zone but it goes into alert mode whenever there is movement anywhere within it's field of view, not just the zone...yet I can't get it to set off an alarm other than by clicking "force alarm" when viewing it.
Any ideas
Any ideas
"The philosophy of one century is the common-sense of the next" - Henry Ward Beecher
- zoneminder
- Site Admin
- Contact:
Idle is when there's nothing, or not enough, happening in the image (as far as ZM is concerned) to cause an alarm.
Recording is when it's recording anyway (you should never see this unless you are in Mocord or Record modes).
Alarm is when something is happening in the frame that will cause (or continue) an event.
Alert is like Idle except it only ever happens after an alarm. If another alarm frame happens when in alert state the event is continued otherwise it drops back to idle after the defined number of frames (post alarm frame count) and the event is closed. It's a sort of hysteresis, though you can turn it off. You cannot get into alert state unless you've been in alarm state.
There's also pre-alarm mode when you specify that you have to have 'x' alarm frames to cause an event.
If your system is going into alarm state then an event has been generated. It will remain in Alert state regardless of what's in the image for the defined number of frames (unless it detects enough movement to cause it to go back to alarm). I don't quite understand when you say your system has gone into Alarm state and then say you can't it to set off an alarm. Can you explain?
Phil,
Phil,
Ok, I have an interesting situation. Using modetect function, the monitor is idling without any problems, but then it jumps into alert state when there's motion. Now, i presume that it goes into alarm state first, and I'm just not seeing this (I'm yet to confirm this though).
The problem lies in that it stays in alert state 'forever'. I have only tested it for about 30mins, but that's more than long enough to determine that it's not working as it should. I have my post frame buffer set to 10, on a 25fps camera, so it shoudln't be going for 30mins. It's not a refreshing problem, as I manually reload the page and it stills says alert state. The event pops up and has an unknown event with a time (Secs) of 0. If I then change the function of the monitor to anythign else, it goes to idle and the secs are calculated.
It seems the problem is changing back from alert to idle even though the motion has stopped. Any ideas?
Another interesting thing is, that sometimes on longer recordings it miscalculates the duration. It has happened twice now, the current one I tested (30mins) shows: 14485494.04 secs duration, which is obviously incorrect, as it equates to something like 4000 hours. The frames seem to be correct, showing just under 9000 for 30mins. If I click on frames to get a complete frame listing, I get some interesting information - the pre-buffer is clearly working, as it shows 10 frames without motion.... now here's the problem. The rest of the frames are still showing motion.. even when it should have stopped. The wierdest part is the last 4 frames though - and remembering this has happened twice now:
You can clearly see that there is a problem with those last four, especially as the time is registering as 10am... the rest of the frames all seem to be correct in regards to time etc, with the exception of the fact that they're all detecting motion with a score of ~50.
Ok, well I have worked out the first issue of the motion continuing for ever. I took a look at the stills again and noticed that it's motion outside int the inclusive zone that is causing it. I have the window as inclusive and the rest of the room as active. I'll have to look into how I can get it stop, when motion in the rest of the room has stopped - I'm with a combination of zones, this is possible.
As for the last four frames, I have a little more info on that too. The last four frames are pitch black, but they still show the motion on certain areas such as the outline of posters on the wall. This is probably related to me having to manually change the function while it's in an alert state - although technically, shouldn't it be in alarm state if there is still motion?
I have one final problem, the email sending and FTP uploading aren't working. Once again this could be related to the same issue. The event is generated, the filters match the event (I run them manually afterwards), they're saved and checked, the options are set to send email and upload. So that's not the problem. I think it must be related to me manually forcing the function change. I'll set the inclusive zone to inactive and see if that fixes that problem.
I shall keep you updated, but if you have any ideas, that'd be great - the last four frame issue is still very odd, esp. with the time changing to 10:00.
8984 Yes 11:48:36 1,713.74 55
8985 Yes 11:48:36 1,713.90 56
8986 Yes 11:48:36 1,714.05 57
8987 Yes 11:48:37 1,714.18 56
8988 Yes 10:00:00 9,999,999.99 68
8989 Yes 10:00:00 9,999,999.99 68
8990 Yes 10:00:00 9,999,999.99 66
8991 Yes 10:00:00 9,999,999.99 66
Ok, good news and bad news. I changed the zone to exclusive, so now it was monitoring everything except for the window. Running as modect function and the motion detection worked, it recorded for the 30secs and when I left it changed the status to idle. I'm still yet to see the alarm state, but that doesn't concern me, it's clearly working.
I still have the issue of the mail, ftp and program not running. I have created a quick script to see if the problem was just with the mail/ftp configuration and set the following options:
Automatically archive: yes
Automatically upload: yes
Automatically email: yes
Program to run: /home/user/scripts/zmnotify.sh
Running the filter manually produces the desired result of showing the event that just occurred, so the filter is working. The script permissions are as follows:
This is the script;
So it should just create a file in /user/zm/notification/ with the filename of en- and the current date appended. The only problem that it could be, is because the script is running as the apache user it doesn't have the appropriate permissions to create the file in that dir. I'll do a su -c and test that, and also change it to create the file in the tmp folder to confirm.
Checking my FTP logs, there's not even an attempted connection by ZM. I have definately checked, and enabled the options. I did a complete system restart to make sure it was all reloaded. I'm really not sure the cause of this one, but I shall keep investigating.
I also need to work out a zone setup with the window situation too... if anyone has any ideas so I can focus on the other issues, that would be great.
[user notification]$ ll /home/user/scripts/zmnotify.sh
-rwxr-xr-x 1 user user 86 Dec 5 10:55 /home/user/scripts/zmnotify.sh
#!/bin/bash
cur_date=`date +%F-%r`
touch /home/user/zm/notification/en-$cur_date
exit
Ok, moving along now ... I still have no idea about why email and FTP isn't working. The script problem is here:
So I'll have to find a quick workaround for that - probably just su inside the script. I'll update when I know what's happening.
[/home/user]# su -c '/home/user/scripts/zmnotify.sh' apache
touch: cannot touch `PM': Permission denied
- securiteaze
you have a bug in your script the date format you are using returns a string with a space in it. you could switch to 24 hour timeor use shell expansion to escape the spaceI would probably use the following because I don't like file names with spaces/symbols
prompt$ date +%F-%r
2004-12-05-09:55:02 PM
prompt$ date +%F-%R
2004-12-05-21:56
touch "/home/user/zm/notification/en-$cur_date"
date +%F-%H-%M
Alert vs. Alarm
Sure,zoneminder wrote: I don't quite understand when you say your system has gone into Alarm state and then say you can't it to set off an alarm. Can you explain?
It is set to "Mocord" and always goes into alert even when activity is outside the only zone I have defined, but never goes into alarm - even when an object moves within the zone...I can't quite figure this behaviour out...
Nevermind
Nevermind...seems to be running properly (as described by the site admin above) now
Does anybody know how I would get rid of problems like (fairly) rapid light-level changes setting off alarms? I've tried setting a maximum blob size but that doesn't seem to cut it...
- lazyleopard
