Noisy Cam
Posted: Fri Dec 03, 2004 12:01 pm
Hi all,
I picked up a couple of relatively cheap b&w outdoor cams to monitor down the side of my house. Unfortunately I installed the cams (dragged cabling through the root etc) and setup the cams to find that they seem to be rather *noisy*
I have to qualify the word noisy. The picture looks very good if a little low res (352x280 is the most I can get out of them). However whenever I configure an active zone I start receiving alerts almost continuously - I look and can not see the movement, but it is alerting.
I have posted one such frame with the 'supposed' movement outlined by the analyser:
There is no notable change in the frame. I have set very high values for sensitivity and still find at times the entire zone is alive with supposed movement, with nothing notable visible in the frame.
My final test was to connect a second camera alongside this one. The second camera is working as expected and is only triggering when there is movement as it should.
Has anybody come across anything wierd like this before ?
Would noise the a likely candidate even if it is not visible ?
Any suggestions or should I continue with my plan to return the camera's ?
Cheers
Jason.
Cheers
Jason.
