I am using zm 1.19.5. in Mandrake 9.1.
ffmpeg 0.4.9-Pre1.
lame 3.96.1
Everything works ok except streaming.
Browsing with IE6 on XP Pro SP2:
With 'Stills' selected in watch window - everything ok.
With 'stream' selected in watch window -
I get a black screen in the Watch window until I right-click, then hit play/pause. Then it plays the stream for a while then stops. If I then select 'Stills' and then 'Stream' , it will play another stream.
Browsing with Netscape on localhost (Mandrake 9.1)
With 'Stream' selected in watch window, netscape prompts me to install plugger, which is already installed.
Thanks in advance for any help.
