Page 1 of 1
Video Generation in ZoneMinder
Posted: Tue Dec 14, 2004 11:51 am
by amit
i am lloking fopr generating videos from events sequence...
clicking on generate Video...
Gives Message ...'Generating Video'
I waited for long enough time but to no avail...
no video is generated
Do anyof you have any idea regarding Video Generation of Events
Please tell me the sequence at the earliest
________
Dream E
Re: Video Generation in ZoneMinder
Posted: Thu Dec 16, 2004 3:01 pm
by michrech
I have an AMD64 3000+ with 1.5gb of DDR400. For a 15 minute or 30 minute (I forget wich it was), it took a VERY long time to generate. (somewhere in the 20-40 minute range). Of course, my computer is keeping track of 12 DCS-900/DCS-1000/DCS-1000w cameras (2 900's, 2 1000w's, and the rest 1000's)
Interestingly enough, that single video I made was the last time I could get the video generation thing to even work. Now I get a message that says "generating video" (or something to that effect) and no even a second later, in the same winow in red letters, I get a failure notice. No idea why. Nothing shows up in /var/log/messages at all. Running 'ffmpeg' from the command line works fine. I'm at my witts end..
So in short, let it run for a while. Especially if your machine is slower than mine.
amit wrote:i am lloking fopr generating videos from events sequence...
Posted: Fri Dec 17, 2004 4:58 pm
by zoneminder
The easiest thing to do in the first instance is to run zmvideo.pl <event id> from the command line. That exactly what the web page does anyway. That way you can check if any errors are produced and also look in zmvideo.log for the same thing.
Phil,
