hardware consensus
Posted: Mon Dec 27, 2004 8:20 pm
Im currently running a P4 2.0, 640mb ram at the moment. 3 camera's at 352x288 analysing @ 10fps and recording at 25fps.
At the moment the system constantly uses about 50mb of swap so it's just baring the loud, crank up the resulution any further and it chokes.
Simply buying more RAM would seem the easiest option but this computer is an old RDRAM machine and the memory for it costs a fortune, so im considering going for a system overhaul to replace the cpu/mobo/ram for something more powerful and cheaper in the longrun.
Ive seen a few people mention dual-xeon systems which seem to run anything you throw at them with ease? Is this true? In a perfect world id like to be running at 768x576 recording at 25fps which the current system just cant handle with 3 camera's. Each process (zms/zmc/zma) seems to use about 160mb of ram when active at this resolution, so im guessing more at higher resolutions. Am I realistically looking at needing 2gig of ram to make this a stable system or am I currently leaking memory somewhere? Any advise would be appreciated.
