I have a color camera, but it is displaying in black and white. My settings are PAL, RGB 555. ( the only setting that works )
It also begins to repeat the top at about an 8th from the bottom.
Any ideas what may be causing this? If there is not a setting in the program itself, then maybe it's my new hardward. =/
________
How to make a vaporizer
Camera Image: Black/White and Repeating Top 1/8th bottom.
i'm using the xguard 4 port card with a swann color/night vision camera. here is an image:
it's just sitting on the floor for a test, but you can see the ceiling repeated on the bottom.
is there any way to frame the picture correctly?
________
Chevrolet gpix concept specifications
________
