ZM 1.9.5 BUG?: mysql threads are left open - please try this
Posted: Wed Jan 05, 2005 3:17 pm
I thought I've solved this problem but I didn't:
SUSE 9.1 PRO with original mysql and apache
ZM 1.9.5
After a few days using ZM suddenly after opening the ZM window in browser I cannot see the camera list in console any more. The problem is to high number of open connections in mysql.
You can check how many open mysql connections you have by typing in command prompt "mysql zm" and then in mysql type "status". Threads: ## shows the number of open mysql threads.
Threads ## is incremented for 1 or 2 when I click to view the real time video and it should come back to the previous number when I close the view window. But it doesn't, it is still higher for 1 or 2 then before I started the video. And when it comes to 100 mysql denies any more connections.
Please check if you experience similar problem, I don't know what could be the problem.
Best regards,
DN
ZM 1.9.5
Best regards,
DN
