starting from the reboot (sorry do not know what is relevant so here it all is, including the grief I get from a Microsoft keyboard along with Linux)
Dave
Jan 8 18:37:50 localhost rc: Starting readahead: succeeded
Jan 8 18:37:52 localhost messagebus: messagebus startup succeeded
Jan 8 18:37:53 localhost cups-config-daemon: cups-config-daemon startup succeeded
Jan 8 18:37:53 localhost haldaemon: haldaemon startup succeeded
Jan 8 18:37:54 localhost zm: Starting ZoneMinder:
Jan 8 18:37:57 localhost fstab-sync[3216]: removed all generated mount points
Jan 8 18:37:59 localhost su(pam_unix)[3257]: session opened for user apache by (uid=0)
Jan 8 18:37:59 localhost su[3257]: Warning! Could not relabel /dev/pts/0 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:38:01 localhost su(pam_unix)[3257]: session closed for user apache
Jan 8 18:38:01 localhost su(pam_unix)[3332]: session opened for user apache by (uid=0)
Jan 8 18:38:01 localhost su[3332]: Warning! Could not relabel /dev/pts/0 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:38:01 localhost zmfix[3333]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:38:01 localhost fstab-sync[3364]: added mount point /media/cdrom for /dev/hdc
Jan 8 18:38:02 localhost zmfix[3333]: INF [Resetting permissions on /dev/video2 to 20606]
Jan 8 18:38:02 localhost su(pam_unix)[3332]: session closed for user apache
Jan 8 18:38:02 localhost su(pam_unix)[3368]: session opened for user apache by (uid=0)
Jan 8 18:38:02 localhost su[3368]: Warning! Could not relabel /dev/pts/0 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:38:04 localhost fstab-sync[3418]: added mount point /media/floppy for /dev/fd0
Jan 8 18:38:06 localhost su(pam_unix)[3368]: session closed for user apache
Jan 8 18:38:06 localhost su(pam_unix)[3446]: session opened for user apache by (uid=0)
Jan 8 18:38:06 localhost su[3446]: Warning! Could not relabel /dev/pts/0 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:38:07 localhost zmc-d2[3450]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:38:07 localhost su(pam_unix)[3446]: session closed for user apache
Jan 8 18:38:07 localhost su(pam_unix)[3451]: session opened for user apache by (uid=0)
Jan 8 18:38:07 localhost su[3451]: Warning! Could not relabel /dev/pts/0 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:38:07 localhost kernel: pwc Failed to set LED on/off time.
Jan 8 18:38:08 localhost zmc-d2[3450]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:38:08 localhost zmc-d2[3454]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:38:08 localhost zmc-d2[3454]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:38:09 localhost su(pam_unix)[3451]: session closed for user apache
Jan 8 18:38:09 localhost su(pam_unix)[3459]: session opened for user apache by (uid=0)
Jan 8 18:38:09 localhost su[3459]: Warning! Could not relabel /dev/pts/0 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:38:11 localhost su(pam_unix)[3459]: session closed for user apache
Jan 8 18:38:11 localhost su(pam_unix)[3464]: session opened for user apache by (uid=0)
Jan 8 18:38:11 localhost su[3464]: Warning! Could not relabel /dev/pts/0 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:38:13 localhost zmc-d2[3471]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:38:13 localhost su(pam_unix)[3464]: session closed for user apache
Jan 8 18:38:13 localhost zmc-d2[3471]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:38:13 localhost su(pam_unix)[3474]: session opened for user apache by (uid=0)
Jan 8 18:38:13 localhost su[3474]: Warning! Could not relabel /dev/pts/0 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:38:15 localhost su(pam_unix)[3474]: session closed for user apache
Jan 8 18:38:15 localhost zm: ^[[60G
Jan 8 18:38:15 localhost rc: Starting zm: succeeded
Jan 8 18:38:23 localhost zmc-d2[3914]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:38:23 localhost zmc-d2[3914]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:38:34 localhost kernel: [drm] Initialized r128 2.5.0 20030725 on minor 0:
Jan 8 18:38:34 localhost kernel: agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
Jan 8 18:38:34 localhost kernel: agpgart: Putting AGP V2 device at 0000:00:00.0 into 1x mode
Jan 8 18:38:34 localhost kernel: agpgart: Putting AGP V2 device at 0000:01:00.0 into 1x mode
Jan 8 18:38:43 localhost zmc-d2[4024]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:38:43 localhost zmc-d2[4024]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:38:49 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:38:49 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:38:52 localhost gdm(pam_unix)[3920]: session opened for user root by (uid=0)
Jan 8 18:38:56 localhost gconfd (root-4102): starting (version 2.8.1), pid 4102 user 'root'
Jan 8 18:38:56 localhost gconfd (root-4102): Resolved address "xml:readonly:/etc/gconf/gconf.xml.mandatory" to a read-only configuration source at position 0
Jan 8 18:38:56 localhost gconfd (root-4102): Resolved address "xml:readwrite:/root/.gconf" to a writable configuration source at position 1
Jan 8 18:38:56 localhost gconfd (root-4102): Resolved address "xml:readonly:/etc/gconf/gconf.xml.defaults" to a read-only configuration source at position 2
Jan 8 18:39:12 localhost kernel: SELinux: initialized (dev hdc, type iso9660), uses genfs_contexts
Jan 8 18:39:24 localhost zmc-d2[4185]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:39:26 localhost kernel: usb 1-2.2: control timeout on ep0in
Jan 8 18:39:26 localhost zmc-d2[4185]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:40:00 localhost gconfd (root-4102): Resolved address "xml:readwrite:/root/.gconf" to a writable configuration source at position 0
Jan 8 18:40:45 localhost kernel: audit(1105209645.739:0): avc: denied { write } for pid=3108 exe=/usr/sbin/httpd name=mod_proxy dev=dm-0 ino=897738 scontext=user_u:system_r:httpd_t tcontext=system_u:object_r:var_t tclass=dir
Jan 8 18:40:47 localhost zmc-d2[4245]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:40:47 localhost zmc-d2[4245]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:40:53 localhost ntpd[2990]: synchronized to LOCAL(0), stratum 10
Jan 8 18:40:53 localhost ntpd[2990]: kernel time sync disabled 0041
Jan 8 18:41:46 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:41:46 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:41:58 localhost ntpd[2990]: synchronized to 66.187.224.4, stratum 1
Jan 8 18:43:00 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:43:00 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:43:28 localhost zmc-d2[4340]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:43:29 localhost kernel: usb 1-2.2: control timeout on ep0in
Jan 8 18:43:29 localhost zmc-d2[4340]: ERR [Failed to set picture Jan 8 18:49:09 localhost zmc-d2[4470]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:49:10 localhost su(pam_unix)[4468]: session closed for user apache
Jan 8 18:49:10 localhost su(pam_unix)[4474]: session opened for user apache by root(uid=0)
Jan 8 18:49:10 localhost su[4474]: Warning! Could not relabel /dev/pts/1 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:49:11 localhost su(pam_unix)[4474]: session closed for user apache
Jan 8 18:49:11 localhost su(pam_unix)[4480]: session opened for user apache by root(uid=0)
Jan 8 18:49:11 localhost su[4480]: Warning! Could not relabel /dev/pts/1 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:49:13 localhost su(pam_unix)[4480]: session closed for user apache
Jan 8 18:49:13 localhost su(pam_unix)[4487]: session opened for user apache by root(uid=0)
Jan 8 18:49:13 localhost su[4487]: Warning! Could not relabel /dev/pts/1 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:49:14 localhost zmc-d2[4490]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:49:14 localhost zmc-d2[4490]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:49:15 localhost su(pam_unix)[4487]: session closed for user apache
Jan 8 18:49:24 localhost zmc-d2[4516]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:49:25 localhost zmc-d2[4516]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:49:39 localhost kernel: audit(1105210179.264:0): avc: denied { write } for pid=3110 exe=/usr/sbin/httpd name=mod_proxy dev=dm-0 ino=897738 scontext=user_u:system_r:httpd_t tcontext=system_u:object_r:var_t tclass=dir
Jan 8 18:49:45 localhost zmc-d2[4522]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:49:45 localhost zmc-d2[4522]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:49:46 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:49:46 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:50:25 localhost zmc-d2[4528]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:50:25 localhost zmc-d2[4528]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:50:47 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:50:47 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:51:45 localhost zmc-d2[4535]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:51:45 localhost zmc-d2[4535]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:51:47 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:51:47 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:52:47 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:52:47 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:53:46 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:53:46 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:54:25 localhost zmc-d2[4539]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:54:26 localhost zmc-d2[4539]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:55:22 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:55:22 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:56:30 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:56:30 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:57:32 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:57:32 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:58:32 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:58:32 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:59:47 localhost zmc-d2[4549]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:44:00 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:44:00 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:45:00 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:45:00 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:46:11 localhost ntpd[2990]: kernel time sync enabled 0001
Jan 8 18:46:26 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:46:26 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:47:41 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:47:41 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:48:41 localhost kernel: atkbd.c: Unknown key released (translated set 2, code 0x81 on isa0060/serio0).
Jan 8 18:48:41 localhost kernel: atkbd.c: Use 'setkeycodes e001 <keycode>' to make it known.
Jan 8 18:48:49 localhost zmc-d2[4397]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:48:49 localhost zmc-d2[4397]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:48:50 localhost su(pam_unix)[4405]: session opened for user apache by root(uid=0)
Jan 8 18:48:50 localhost su[4405]: Warning! Could not relabel /dev/pts/1 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:48:51 localhost su(pam_unix)[4405]: session closed for user apache
Jan 8 18:48:51 localhost su(pam_unix)[4408]: session opened for user apache by root(uid=0)
Jan 8 18:48:51 localhost su[4408]: Warning! Could not relabel /dev/pts/1 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:49:02 localhost su(pam_unix)[4408]: session closed for user apache
Jan 8 18:49:03 localhost su(pam_unix)[4434]: session opened for user apache by root(uid=0)
Jan 8 18:49:03 localhost su[4434]: Warning! Could not relabel /dev/pts/1 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:49:04 localhost su(pam_unix)[4434]: session closed for user apache
Jan 8 18:49:04 localhost su(pam_unix)[4440]: session opened for user apache by root(uid=0)
Jan 8 18:49:04 localhost su[4440]: Warning! Could not relabel /dev/pts/1 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:49:04 localhost zmfix[4441]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:49:04 localhost su(pam_unix)[4440]: session closed for user apache
Jan 8 18:49:04 localhost su(pam_unix)[4443]: session opened for user apache by root(uid=0)
Jan 8 18:49:04 localhost su[4443]: Warning! Could not relabel /dev/pts/1 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:49:08 localhost su(pam_unix)[4443]: session closed for user apache
Jan 8 18:49:08 localhost su(pam_unix)[4463]: session opened for user apache by root(uid=0)
Jan 8 18:49:08 localhost su[4463]: Warning! Could not relabel /dev/pts/1 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:49:08 localhost zmc-d2[4466]: INF [Debug Level = 0, Debug Log = ]
Jan 8 18:49:08 localhost su(pam_unix)[4463]: session closed for user apache
Jan 8 18:49:09 localhost su(pam_unix)[4468]: session opened for user apache by root(uid=0)
Jan 8 18:49:09 localhost su[4468]: Warning! Could not relabel /dev/pts/1 with user_u:object_r:devpts_t, not relabeling.Operation not permitted
Jan 8 18:49:09 localhost zmc-d2[4466]: ERR [Failed to set picture attributes: Invalid argument]
Jan 8 18:49:09 localhost zmc-d2[4470]: INF [Debug Level = 0, Debug Log = ]
