Anyone has recommendations on good priced outdoor day/night
cameras ?
Looking for distance of about 50 feet.
Seems like there is a huge disparity amongst cameras.
Thanks,
L
Camera recommendations
I bought a CC70 from RF Concepts which seems pretty good. Always watch out for the number of "TV lines" in the spec as this will have a big impact on the quality of the captured image. I would try and get one with 480, cost permitting.
It has an array of LED's which automatically come on in low light and the camera also switches to B&W. This saves buying a separate IR. illuminator but a small drawback seems to be that Zoneminder gets triggered by raindrops falling close to the lens. It may be possible to avoid this with a suitable zone setting (or putting the thing under your roof overhang!?). Please note that you can't put it behind a window due to the LEDs.
I ordered the PSU on the same page as the camera but when it came there was one already supplied in the camera box so I ended up with a spare.
Also bear in mind that the camera is fixed focus and the lens is not changeable, so order the correct focal length for the 'zoom' that you require.
I have some infrared cameras that I sell:
http://www.bluecherry.net/store/catalog ... Path=21_29
The YCC series have the option of a built-in heater for use in outside areas that might be cold (below 40 degrees F)
Contact me at curt@bluecherry.net if you have any questions, I give a 15% discount to zoneminder users.
You might want to take a look at
http://www.supercircuits.com
They have great quality and selection of products at resonable prices.
And if you have any questions they are eager to help.
Cordel
Cordel
You can use the coupon of 'zoneminder' to get a automatic 15% off Cameras and Capture cards from www.bluecherry.net
Do you still offer this? I tried the coupon code but it doesnt work.curtishall wrote:You can use the coupon of 'zoneminder' to get a automatic 15% off Cameras and Capture cards from www.bluecherry.net
The coupon code is only available for capture cards. For everything else you can use 'FirstTime' (no quotes) for 10% off
BadFish wrote:Do you still offer this? I tried the coupon code but it doesnt work.curtishall wrote:You can use the coupon of 'zoneminder' to get a automatic 15% off Cameras and Capture cards from www.bluecherry.net
