Installation Advice
Posted: Mon Jan 17, 2005 8:15 am
Hi All,
I urgently need to set up a security system at my house due to a few recent 'incidents'
I've tried installing it now on both Suse 9.1 and Fedora core 3.
Both failed with different errors - one during configure and one during running (PHP unable to find DB connection function)
From searching on the web both of these errors seem to be down to version mismatches/incompatibilities with Apache, PHP and MySQL.
My questions are:
1. Has anyone done an installation step-by-step guide for any particular distros - the ones I have available are any version of Redhat, Suse 9.1.
2. Should I use the PHP, MYSQL and Apache that is supplied with the distro or compile my own?
3. If I chose not to use the packages supplied with the distro and wanted to compile my own, what versions should I use and which particular MYSQL modules/packages would I need (I note there are about 7 - server, client etc)
4. Are there any distros where this works 'out of the box' without messing around installing different versions.
Many thanks in advance for your advice.
My questions are:
