Exit status 255
Posted: Sun Jan 23, 2005 9:33 am
I've installed 1.20.0, but I get a broken image when I try to view a monitor. This error seems to occur a bit on the forums, but I couldnt find a successful resolution.
/tmp/zmdc.log gives this repeated:
There are no other /tmp/zm*.log files.
/var/log/messages gives this over and over:
My capture card is a Conexant BT878A, using the Linux 2.6.7 video4linux/bttv drivers.
The kernel seems to be detecting the card and assigning it /dev/vdi0 and /dev/video0. I linked /dev/vdi0 to /dev/video4 so I could try zoneminder with that as the device, with no luck.
Any assistance would be greatly appreciated.
Thanks in advance,
Patrick
Starting pending process, zmc -d 4
'zmc -d 4' started at 05/01/23 17:13:15
'zmc -d 4' starting at 05/01/23 17:13:15, pid = 15547
'zmc -d 4' crashed at 05/01/23 17:13:15, exit status 255
Command 'zmc -d 4' removed from pending list at 05/01/23 17:13:22
'zmc -d 4' started at 05/01/23 17:13:22
'zmc -d 4' starting at 05/01/23 17:13:22, pid = 15558
'zmc -d 4' crashed at 05/01/23 17:13:22, exit status 255
'zmc -d 4' starting at 05/01/23 17:13:22, pid = 15560
Can't find process with command of 'zma -m 1
Jan 23 17:13:22 server zmc_d4[15560]: INF [Debug Level = 0, Debug Log = <none>]
Jan 23 17:13:27 server zmc_d4[15573]: INF [Debug Level = 0, Debug Log = <none>]
Jan 23 17:13:37 server zmc_d4[15587]: INF [Debug Level = 0, Debug Log = <none>]
Thanks in advance,
Patrick
