I just finnished packaging zm for FC3 I think. I used Oskins zminit script and based every thing pretty much on what he done. I need a few brave souls to test it out.
PM me if your interested.
Cheers,
Cordel
PS I just built it onto a mini distro of FC3 I'll keep ya posted on how it goes.
I should know if everything is good... or not in 30 minutes
Ran into a hitch with the init script. Affaid we'll have to wait for Oskin for his super fine work.
just a bit beyond me at the moment. or maybe I've been up and awake to long
I unfortunately have to leave for work so by the time I get back I'll probably be wiped. But I'll tinker somemore when I can.
Cheers,
Cordel
Packages for Fedoa Core 3 at ftp://cordel.no-ip.info/pub/linux/zonem ... Extra-RPMS
All the extras for ZM as well. If there is any missing perl modules let me know and I'll get them built.
Everything seems to work fine on Fedora with no login issues. Try it out and let me know if there is something I need to address.
Cheers,
Cordel
Updated ftp directory
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
No need to copy it any where. Type in the url http://localhost/zm
If you look in /etc/httpd/conf.d/zm.conf is set up as a alis so all your static files are in /usr/lib/zm and all your data is in /var/lib/zm
Cheers,
Cordel
PS the credit goes to Oskin for this.
The Steamming issue with no autherazation is fixed in the the next version.
It's on my ftp now as zm-1.20.1-RC1
As for the SQL error it is still present in the the release canidate and to ellaborate this error it shows up from the settings link above the streaming video. confermed
Madmax I'm testing the new version and I do not recieve this error. How would I duplicate it?
What are your settings?
When I try to run zmtrigger, I get the following error. I have the same problem with zmx10.pl
[root@zoneminder bin]# perl zmtrigger.pl
Can't open config file: No such file or directory at zmtrigger.pl line 45.
BEGIN failed--compilation aborted at zmtrigger.pl line 73.
Did you install zm-X10? It's on the ftp server as well. Also have you upgraded the database?
It looks like zmtriggers looks to the database to get it's config info. Check the readme for usage of zmtriggers.
Cordel
Cordel,
Thanks for all of the help. I apparently did not install the X10 rpm. That fixed X10 and triggered events. I still was unable to get zmtrigger.pl to run at all. But, I am happy for now with X10.
