I am creating this as a new thread as directed by phil.
Camera: Axis 206w
zoneminder: 1.20.0
OS: Mandrake 9.2
Apache: 2.0
I can view my camera directly by hitting
http://192.168.0.208/axis-cgi/mjpg/video.cgi
and have that listed in the source tab
I have events recording or so it says but am totally unable to play or view anything live, nor is anything tripping it to begin capture.
I have changed from http 1.0 to http 1.1 and still the same things happen.
Anyone have a clue what is going on here????
Axis 206W, not streaming through zoneminder
still unable to get streaming or images in zoneminder
Ok, here is what i am getting in terms of logs.
[root@superbox zoneminder]# tail -f *
==> zmaudit.log <==
==> zmdc.log <==
'zmwatch.pl' starting at 05/02/07 18:43:38, pid = 21217
'zmwatch.pl' started at 05/02/07 18:43:38
Starting pending process, zmc -m 1
'zmc -m 1' starting at 05/02/07 18:43:41, pid = 21223
Starting pending process, zma -m 1
'zma -m 1' starting at 05/02/07 18:43:41, pid = 21224
'zmc -m 1' started at 05/02/07 18:43:41
'zma -m 1' started at 05/02/07 18:43:41
'zmc -m 1' crashed at 05/02/07 18:43:41, exit status 255
'zma -m 1' crashed at 05/02/07 18:43:41, exit status 255
==> zmfilter.log <==
Scanning for events
==> zmpkg.log <==
Command: start
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl check'
Removing shared memory
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmfix'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl status'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmc -m 1'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zma -m 1'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmfilter.pl'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmaudit.pl -d 900 -y'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmwatch.pl'
==> zmwatch.log <==
Watchdog starting at 05/02/07 18:43:39
Watchdog pausing for 30 seconds
==> zmdc.log <==
'zmc -m 1' starting at 05/02/07 18:43:51, pid = 21230
'zma -m 1' starting at 05/02/07 18:43:51, pid = 21231
'zmc -m 1' started at 05/02/07 18:43:51
'zma -m 1' started at 05/02/07 18:43:51
'zmc -m 1' crashed at 05/02/07 18:43:51, exit status 255
'zma -m 1' crashed at 05/02/07 18:43:51, exit status 255
==> zmwatch.log <==
Can't get shared memory id '2053971969': No such file or directory
i am fairly sure the settings i have in the config for the monitor are correct.
[root@superbox zm]# tail -f /var/log/zoneminder/*
==> /var/log/zoneminder/zmaudit.log <==
Filesystem event '3/3' does not exist in database, deleting
Found orphaned frame records for event '3', deleting
Filesystem event '3/5' does not exist in database, deleting
Filesystem event '3/6' does not exist in database, deleting
Filesystem event '3/8' does not exist in database, deleting
Filesystem event '3/7' does not exist in database, deleting
Found orphaned frame records for event '5', deleting
Found orphaned frame records for event '6', deleting
Found orphaned frame records for event '7', deleting
Found orphaned frame records for event '8', deleting
==> /var/log/zoneminder/zmdc.log <==
'zma -m 1' started at 05/02/07 18:39:15
'zma -m 1' crashed at 05/02/07 18:39:15, exit status 255
'zmc -m 1' starting at 05/02/07 18:40:34, pid = 20902
'zmc -m 1' started at 05/02/07 18:40:34
'zmc -m 1' crashed at 05/02/07 18:40:34, exit status 255
'zma -m 1' starting at 05/02/07 18:40:35, pid = 20904
'zma -m 1' started at 05/02/07 18:40:35
'zma -m 1' crashed at 05/02/07 18:40:35, exit status 255
==> /var/log/zoneminder/zmfilter.log <==
Scanning for events
Scanning for events
Scanning for events
Scanning for events
Scanning for events
Scanning for events
Scanning for events
Scanning for events
Scanning for events
Scanning for events
==> /var/log/zoneminder/zmpkg.log <==
Command: start
==> /var/log/zoneminder/zmupdate.log <==
Update agent starting at 05/01/25 04:16:49
Update agent starting at 05/01/25 04:20:14
Update agent starting at 05/01/25 08:08:13
Update agent starting at 05/01/25 10:02:35
Update agent starting at 05/01/25 14:54:02
Update agent starting at 05/01/25 14:55:06
Update agent starting at 05/01/25 14:58:51
Update agent starting at 05/01/25 15:05:01
Update agent starting at 05/01/25 15:29:55
Update agent starting at 05/01/25 15:50:09
==> /var/log/zoneminder/zmvideo.log <==
Duration: 00:10:00.6, bitrate: N/A
Stream #0.0: Video: rawvideo, yuvj420p, 320x240, 19.48 fps
Output #0, mpeg, to 'Event-7.mpg':
Stream #0.0: Video: mpeg1video (hq), 320x240, 15.00 fps, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
[mpeg1video @ 0x40284008]MPEG1/2 doesnt support 15/1 fps
Error while opening codec for stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width or height
Error: 1 at /usr/local/bin/zmvideo.pl line 273.
==> /var/log/zoneminder/zmwatch.log <==
==> zmaudit.log <==
==> zmdc.log <==
Scanning for events
==> zmpkg.log <==
Command: start
==> zmwatch.log <==
==> zmdc.log <==
==> zmwatch.log <==
Scanning for events
Scanning for events
Scanning for events
Scanning for events
Scanning for events
Scanning for events
Scanning for events
Scanning for events
Scanning for events
Scanning for events
Command: start
Stream mapping:
Stream #0.0 -> #0.0
Solved, axis streaming solution in other thread
Did solve this finally.
I documented this in the following thread.
http://forums.mozillazine.org/viewforum.php?f=38
More information please
tek,
what problem did you solve? Several of us have been experience the problem of not seeing streaming video in ZM under FC3 (mine from axis 2100, CTR_Mint from local device). I am seeing some some of the same errors you have. I went to the mozillzine site you referenced but it takes me to the general site. Where is the thread for your solution? I tried searching for various keywords (zoneminder, streaming video, tek....)
It may not fix my problem but I am still looking for solutions and often find little bits and pieces in how other problems were solved.
Thanks,
Pete
Thanks,
Pete
P. Brown
pbrown@knotranet.com
