Couple of startup problems
Posted: Tue Feb 01, 2005 6:15 pm
Trying to use 1.20.0
Everything seemed to compile, install and go fine. I am having 2 problems and I don't know if they're related.
I chose during the installation to not use authentication, yet when I go to the ZoneMinder page, I get prompted. I try admin/admin and I just get the same prompt over and over. I tried no password as well. I have seen some mention of this problem here, not sure if it's the same thing.
Secondly, I don't know if it's related, but I when I tried to start the zm service, I got some errors (to be included below). I wasn't sure if I needed to go to the web page to configure some stuff the rest of the way before the service would start, or if I need the service to start in order to to login.
RedHat V9
Here's the errors I got when I tried to start the service...
Thanks!
RedHat V9
Value: no
Description: Authenticate user logins to ZoneMinder
Value: hashed
Description: Method used to send authentication information
Value: what3ver22yki
Description: Secret used when encoding authentication information
service zm start
Starting ZoneMinder: Use of uninitialized value in transliteration (tr///) at /usr/local/bin/zmpkg.pl line 52, <CONFIG> line 5.
Use of uninitialized value in string eq at /usr/local/bin/zmpkg.pl line 53, <CONFIG> line 5.
Undefined subroutine &main::ZM_DB_NAME called at /usr/local/bin/zmpkg.pl line 64.
BEGIN failed--compilation aborted at /usr/local/bin/zmpkg.pl line 74.
[FAILED]
