Can't bind address problems.
Posted: Thu Feb 03, 2005 11:18 am
I am running ZM 1.19.5 on Knoppix (3.7) that has been installed to Hard Disk.
I had a little trouble getting ZM to run initially, but for the last 2 months or so it has been working reliably.
The only way i could get my devices to turn green was to change from modetect to monitor, trying to run any other way didnt work, still i was happy as i did have a working system.
My eventual aim was to be able to run direct from a remastered Knoppix CD, and i am still working on this, and will release this if / when i ever get it working, with this in mind i tried to get the zm script in the /etc/init.d directory to work, during this attempt i have broken my hdd version.
The first hint of this in the logfiles (zmdc.log) is
"Can't locate MIME/Entity.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.8.4 /usr/local/share/perl/5.8.4 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8 /usr/local/lib/site_perl) at /usr/local/bin/zmfilter.pl line 87."
Now zmc wont start, this shows up in the same log file as "Can't bind: Address already in use at /usr/local/bin/zmdc.pl line 166"
Can anyone give me a hint as to what has gone wrong ?.
Here is a section of the zmdc.log.
Can't bind: Address already in use at /usr/local/bin/zmdc.pl line 166.
Starting pending process, zmfilter.pl
'zmfilter.pl' starting at 05/02/02 20:09:49, pid = 32309
'zmfilter.pl' started at 05/02/02 20:09:49
BEGIN failed--compilation aborted at /usr/local/bin/zmfilter.pl line 87.
'zmfilter.pl ' crashed at 05/02/02 20:09:49, exit status 2
'zmc -d 0' died at 05/02/02 20:10:21
'zmc -d 0' starting at 05/02/02 20:10:21, pid = 32364
'zmc -d 0' started at 05/02/02 20:10:21
Server starting at 05/02/02 20:10:32
zmc(32364): Operation not permitted
zma(30344): Operation not permitted
zma(30353): Operation not permitted
zmaudit.pl(30362): Operation not permitted
zmwatch.pl(30367): Operation not permitted
zmupdate.pl(30374): Operation not permitted
Server starting at 05/02/02 20:10:42
Server starting at 05/02/02 20:10:52
Server starting at 05/02/02 20:11:03
