Hi, Phil!
There was a question: how to struggle with the "striped" image?
for example see: http://syr.nnov.ru/stripe.jpg
"Striped" images
- zoneminder
- Site Admin
- Contact:
This is called 'interlacing' and is caused by your camera not being able to capture all the lines in an image at once. So it does two images at slightly different times and merges them together. The simple solution is to drop your image size to one that your camera without interlacing.
If you search for interlace in the forums you should find several threads discussing the issue.
Phil
Phil
