Rebuild PurgeWhenFull Filter
skydiver
Post by skydiver »
I inadvertantly deleted the built in PurgeWhenFull filter while playing around with my setup now that I have finally got everything up and running. Could someone walk me through re-creating it? I would rather not have to re-install just to rebuild the filter.
I had a bear of a time just getting this up and running (over 7 months of trying to get the system up due to incompatabilities with my capture card and different distro and different motherboard combos).and don't want to risk breaking it again.
Thanks for the help and bravo on a GREAT PROJECT, I AM VERY happy with the system. Now I just need to upgrade my cameras to higher quality units with some that will not have noisy images and problems with auto iris whiting out the images. in the bright sun. Any suggestions on good day and night camera at a reasonable price would be gladly accepted.
Scott
skydiver
Post by skydiver »
Nevermind, I found the INSERT statement in the sql schema file as was able to bring it in via phpMySqlAdmin. I just didn't know the logic that was bing used to automatically delete the files.
