Problem with Labtec Webcam Pro USB cam
Posted: Sat Feb 19, 2005 10:14 am
Hello
I had tested Labtec Webcam Pro using the latest spca5xx driver from 2005-02-06.
When I use spcagui, I get prefect picture.
If I use motion or zm 1.20.1 I get picture with garbage at the bottom 5-10 pixels height in picture.
The spca reports following when loads driver with Labtec
Labtec Webcam Pro Zc0302 + Hdcs2020
I tested with some genius cams, that have spca chip, and use the same driver as labtec.
These cams give purer immage quality, but does not have garbage line in last 5-10 pixels.
While Labtec have perfect immage quality, in above part of the picture.
Has aneyone had similar problem?
Also, change from RGB24 for any cam on spca5xx driver, results in some error. And since I set up zm to not produce video on error, I dont get any picture.
If I choose 2 times in a roll mode that zm cant initialize with that driver, I must reboot.
I use FC3, compiled zm manualy.
Compiled required applications and libs from srpm-a on Doug's repository.
