RH9 problem
us5we
RH9 problem
Post by us5we »
[root@ur5wa scripts]# ./zm start
Starting ZoneMinder: Use of uninitialized value in transliteration (tr///) at /usr/local/bin/zmpkg.pl line 52, <CONFIG> line 5.
Use of uninitialized value in string eq at /usr/local/bin/zmpkg.pl line 53, <CONFIG> line 5.
Undefined subroutine &main::ZM_DB_NAME called at /usr/local/bin/zmpkg.pl line 64.
BEGIN failed--compilation aborted at /usr/local/bin/zmpkg.pl line 74.
[FAILED]
using RH9 with kernel 2.4.29
mysql-bench-3.23.58-1
mysql-server-3.23.58-1.9
mysql-3.23.58-1
php-mysql-4.2.2-17
mysql-devel-3.23.58-1
perl-5.8.0-88
Looks like I'm missing something...
73, Vic
zoneminder
Site Admin
Post by zoneminder »
This is related to the UTF problem I think, try looking in the long "can't login" for a solution or search for 'utf' on the forums.
Phil
oskin
Post by oskin »
Phil, IMHO solution of this problem is described here: http://www.zoneminder.com/forums/viewto ... =6528#6528
