auth expire?
fernando
auth expire?
Post by fernando »
Phil says.
You have to be a little careful as the 'auth' string is time sensitive and so will expire
now my question is.
what happens if i wach a monitor all the day? this will stop function? since the auth expire.
Fernando
zoneminder
Site Admin
Post by zoneminder »
No. Once you're connected you're fine, but if you try and reconnect later on with the same string or from a different IP then it won't work.
Phil
