Hi all,
I've install zm without problem but when I try to lunch the service I obtain this:
[root@proxy bin]# /usr/local/bin/zmpkg.pl
Use of uninitialized value in transliteration (tr///) at /usr/local/bin/zmpkg.pl line 51, <CONFIG> line 5.
Use of uninitialized value in string eq at /usr/local/bin/zmpkg.pl line 52, <CONFIG> line 5.
Undefined subroutine &main::ZM_DB_NAME called at /usr/local/bin/zmpkg.pl line 63.
BEGIN failed--compilation aborted at /usr/local/bin/zmpkg.pl line 73.
Have you some idea? I'm not a perl wizard
Regards
problem with rh9 and zm 1.20.1
- zoneminder
- Site Admin
- Contact:
