Page 1 of 1
fixing status label in index.php
Posted: Wed Mar 09, 2005 7:28 am
by bzo
Just upgraded from 1.19.4 to 1.20.1. Took a bit of work, but everything seems to be working fine now. The only remaining problem, which is just cosmetic, is that the status doesn't show correctly. It always says "Stopped" no matter what. Any hints on how to debug this problem? Thanks!
Posted: Thu Mar 10, 2005 12:38 am
by bzo
ok, did some more looking around and it seems like the problem is that the php calls are not getting the output from the various perl scripts. In zm_funcs.php/daemonCheck(), $result = exec ($string) where
$string is /usr/local/bin/zmdc.pl check
doesn't populate $result. Running the above command in a shell works fine and prints out "running"
A similar thing seems to be happening in zm_html_view_console.php where $monitor['zmc'] and $monitor['zma'] are empty because they are not capturing the results of the scripts they are calling. This causes the sources to all appear red in the display.
Any help appreciated on figuring out this problem.
Posted: Thu Mar 10, 2005 11:25 am
by zoneminder
Is is possible you originally ran zmdc.pl as root and so the /tmp/zmdc.sock is owned by root and so your apache user doesn't have permissions?
Phil
Posted: Thu Mar 10, 2005 9:06 pm
by bzo
that may have been it? I was playing around with it and it started working. I was tweaking the perl scripts for the RH9 issue, so I'm not sure whether it was that and/or the restarts that fixed it. In any case, thanks for the response!
