pre and post buffer - which framerate to use for calculating
Posted: Fri Mar 11, 2005 11:04 am
With each motion detect alarm I want to capture 10 seconds before, and 10 seconds after each event. What I want to know though, as I cant see it in the readmy, is which value the pre and post event buffer actually uses.
My camera's are limited to 10fps while analysing, then unlimited, which is 25fps when recording an alarm. So, will the 10 seconds before the alarm triggers recorded by zonealarm at 10 or 25 fps, and will the 10 seonds after the alarm has ended keep running at 25fps or will it drop back to 10fps?
