Hi all,
I have searched a lot the forum on that topic but with no success.
It looks like cambozola is not working for me (streaming ok on monitor window with mozilla 1.7.2 but not with IE).
After reading the different topics, I understood (correct me if I am wrong) that:
zm checks if the navigator is ok (depending if ZM_CAN_STREAM is on auto), if not or ZM_CAN_STREAM=no, it uses cambozola to stream.
I used Ross RPM for Mandrake 10.1, cambozola is in /usr/lib/html
Here are my options:
video
ZM_VIDEO_STREAM_METHOD=jpeg
ZM_VIDEO_LIVE_FORMAT=asf
ZM_VIDEO_REPLAY_FORMAT=asf
tools
ZM_CAN_STREAM=auto
ZM_RAND_STREAM=no
ZM_OPT_CAMBOZOLA=yes
ZM_PATH_CAMBOZOLA=/zm/cambozola.jar
ZM_OPT_MPEG=ffmepg
any suggestions welcome
how to use cambozola ?
It is so good to self-answer
I suspect that the zm RPM for Mandrake 10.1 does not set a correct path for cambozola
I move ZM_PATH_CAMBOZOLA=/zm/cambozola.jar to ZM_PATH_CAMBOZOLA=cambozola.jar
and it's working now except for an usb cam. Unfortunately, I still have a bad montage aspect. I will try with cambozola version 0.22 but the montage problem (all the monitors not active at the same time) is perhaps not due to a streaming reason.
