I have two monitors, on two inputs of a BT878 capture card, both running the same B/W composite cameras.
Now one of them won't record - I can view the live monitor just fine, and when there is no motion, the monitor's 'source' line is green... but when there is motion, the name changes to yellow, and there are no events recorded.
zmdc.log shows:
encoder:/tmp# tail zmdc.log
'zmf -m 1' crashed at 05/03/21 20:57:51, exit status 11
'zma -m 1' crashed at 05/03/21 20:57:51, exit status 255
Starting pending process, zma -m 1
'zma -m 1' starting at 05/03/21 21:07:51, pid = 6024
Starting pending process, zmf -m 1
'zmf -m 1' starting at 05/03/21 21:07:51, pid = 6025
'zma -m 1' started at 05/03/21 21:07:51
'zmf -m 1' started at 05/03/21 21:07:51
'zmf -m 1' crashed at 05/03/21 21:07:51, exit status 11
'zma -m 1' crashed at 05/03/21 21:07:58, exit status 255
I have manually installed ffmpeg 0.4.8 since installing ZM, which appears to work fine.
Any ideas why this would cease capturing events after nearly 32000 events? (the other monitor is up to 37000+ events)
