no image when streaming (cont)
Posted: Mon Mar 21, 2005 11:37 pm
Thanks to zoneminder and maciekc for your sugestions. I tried all the tests and all checks out. BUT - still no images.
I checked all error logs and no messages. I tested php and cgi - all seems to work.
Are there any other additional tests you can suggest?
Thanks!
scott
Here is a summary from the Mar1 thread..
This may not be a zoneminder issue but maybe someone will know. Could be a V4l problem.
he symtom is I'm streaming some content ~ 640 bytes (refresh- jpeg) but no image. Checked and corrected all error messages. No change. >Tried running ZMC as suggested and does not exit. ZMU returns realistic >data. Strict video error logging is set and I use authentication. Monitor >labels are all green in the Zoneminder console. Same results locally and remote.
Everything seems to be stable otherwise. Used mozilla, netscape, explorer, opera on linux and win2000. I also see no images using GV4L in xorg for 4 channels. Videodog pulls in still images on all channels. XAWTV crashes the system but hand generated a .XAWTV file. May be an Xorg issue. I dont usually use X anyway for this system.
Here are the details:
- Gentoo with 2.6.10-r6 kernel - ASROCK K7S41GX
- SIS chipset MB
- video capture - Grandtec multi 4 ch. BTTV - 878 chip. similar to Pico2000 - card 77
- AMD sempron
- PHP 4.3
- Apache 2.0.52
- Zoneminder 1.20.1 - built from sources.
Some questions:
- Do I need to have framebuffer activated?
- I suspect possible memory issue although no errors in logs. Tried relocating common memory as in options.
- Do I need to execute v4l-config? I've tried anyway with no changes.
- DMESG shows everything to be OK - I think. BTTV Card is detected.
- Transcode says cant read video0 configuration. Dont know why.
- It seems like I just cannot get the video from the card even though the zm log file says streaming at 10 fps on the first channel.
- tried mpeg / jpeg same result.
Any help would or suggestions would be very much appreciated!
Thanks!
From maciekc:
Check apache log.
I think that your zms in cgi-bin is not running correctly. Maybe you don't have cgi script support in apache. Take a look at image source in monitor window and paste it to browser address - you'll check zms.
I have something like that:
http://localhost/cgi-bin/zms?mode=jpeg& ... n&pass=xxx
from Zoneminder:
zmu has an option to dump an image to the current directory (-i), you could try that and if you get a genuine image from your cam then it is almost certainly a streaming problem, otherwise we need to look elsewhere.
Congratulations on a comprehensive and informative problem report by the way, it makes things much easier to track down.
Phil
Thanks!
scott
- SIS chipset MB
- AMD sempron
- PHP 4.3
- Apache 2.0.52
Some questions:
Thanks!
From maciekc:
Check apache log.
from Zoneminder:
Phil
