MySql set up problem ?
Posted: Tue Mar 22, 2005 4:49 am
Ok, a little progress here, suspect I haven't got the right DB, user etc set-up in MySql.
If so how can I check what Mysql is working with and add to /change ?
Sorry for being so slow at this but this is all new ground for me !
PS running Mysql 4.0.24
Thanks Tim
[root@amdxp1800 zm-1.20.1]# perl zmconfig.pl -noi
Loading config from 'zmconfig.txt'
Loading config from DB
DBI connect('database=zm;host=localhost','timf_mys',...) failed: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) at zmconfig.pl line 1611
Error: unable to load options from database: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
Saving config to 'zmconfig.txt'
Saving config to DB
DBI connect('database=zm;host=localhost','timf_mys',...) failed: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) at zmconfig.pl line 1515
Error: unable to save options to database: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
Generating 'src/zm_config_defines.h'
Processing 'zm.conf'
Processing 'src/zm_config.h'
Processing 'web/zm_config.php'
Processing 'scripts/zmdc.pl'
Processing 'scripts/zmwatch.pl'
Processing 'scripts/zmaudit.pl'
Processing 'scripts/zmfilter.pl'
Processing 'scripts/zmtrigger.pl'
Processing 'scripts/zmx10.pl'
Processing 'scripts/zmpkg.pl'
Processing 'scripts/zmupdate.pl'
Processing 'scripts/zmvideo.pl'
Processing 'scripts/zm'
Processing 'db/zmschema.sql'
etc etc
Thanks Tim
Saving config to DB
etc etc
