Hi. I'm getting streams of errors regarding the ring buffer size. I've got 4 Axis 205 cameras set to modect with the ring buffers on each set to 10. If I set it to anything more I get shm errors, even though I have set the shm size to 500M!
The server has 1G of RAM which should be enough for 4 cameras, no?
Cheers for any advice.
Ringbuffer Issue
- zoneminder
- Site Admin
- Contact:
I suspect a config error somewhere. I can run about 15 cameras with ring buffers ranging from 40 to 100 in the same amount of memory so you shouldn't have any problem. 10 really is too small and I would recommend 40 at the minimum. It's always worth fully restarting ZM when increasing shared memory usage in any way.
When you say you have set the shm size to 500M, where did you do this?
Phil
Phil
- zoneminder
- Site Admin
- Contact:
